Jeez - - this must be my month for Maytag breakdowns........
My Neptune Washer (about 3 years old) has sprung a leak! I noticed a good amount of water coming out from underneath the washing machine. Took a quick look last night - - the hot and cold input look nice and dry. Water seems to be coming out from somewhere underneath. To do a quick check, I mopped the floor and then ran just a spin cycle - - it seems that as soon as I ran the spin cycle, more water started to come out from underneath the washer. I would apprecaite info from the group on where I should start looking on this unit. thanks all, Kerry |
**My Neptune Washer (about 3 years old) has sprung a leak!** Model#? http://www.applianceaid.com/model.htmlSome model# helps. Most common leaking trouble makers I have seen are a tear in the rubber door boot, drain pump for the water and dispensor hoses on the stacked unit. **Took a quick look last night - - the hot and cold input look nice and dry. Water seems to be coming out from somewhere underneath** Couldn't pin point where the water was comming from....front/back/sides?? jeff.
Jeff - - the model number of the Maytagwasher is: MAH5500BWW I've not been able to pinpoint where the water is actuallycoming from - - I need to move some stuff around to do get a better view, but it does appear as if it is coming from somewhere within thelower partof the washer (could also be drippingdown fromsomewherefurther up)- - I see asmall amount of water on the floorat the front, with a much heaver seepage from the left side (looking at machine from front). Do you have any suggestions on how/where to start the troubleshooting process with this unit? thanks, Kerry |
G'day,
**Do you have any suggestions on how/where to start the troubleshooting process with this unit?** Load of clothes, remove the front panal and reinstall the door so you can run a load with the front panal off, and have a flash light handy. That's what a tech would do ![]() jeff.
| Maytag Washing Machine wont spin or rinse!!! | mymaytagdied | Maytag/Magic Chef/Admiral/Jenn-Air | 5 | December 12th, 2006 12:11 PM |
| Maytag Neptune 9700 | mommaleaman | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | June 28th, 2006 11:06 PM |
| Maytag Washing Machine | Baker | Maytag/Magic Chef/Admiral/Jenn-Air | 9 | November 23rd, 2005 01:03 PM |
| Maytag Neptune leaking (another one) | kristie_jeff | Maytag/Magic Chef/Admiral/Jenn-Air | 5 | August 11th, 2005 08:12 PM |
