Results 1 to 4 of 4
Thread: Maytag A712: change washer timer or timer motor?
    thomaszr is offline Member
    Jul 2012
    Hawaii
    Question Maytag A712: change washer timer or timer motor?
    Model Number: A712
    Brand: Maytag
    Age: More than 10 years
    I've had a Maytag A712 washer for a long time. (It was here when I moved in 11 years ago)
    Using the left hand side of the dial or "REGULAR FABRICS" side of the dial. It stops before the rinse cycle; If I push in, advance the dial abit and then pull it back out it resumes.
    It will then stop again before the spin cycle; If I lightly push down on the knob, the washer will thump & click abit and then start to spin/drain and complete the cycle.
    It's done this for a little while and I've been able to live with it.
    Recently though, it has done all of the above and then after a brief pause, will continue on past the 12 o'clock/stop position and to the Right hand side or "PERMANENT PRESS" side and start a whole new wash cycle.
    How do I know if I need to change the $56 TIMER MOTOR or the $156 WASHER TIMER (which I think includes the TIMER MOTOR)?
    Or am I on the wrong track and need to change something else?
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jul 2012
    Hawaii
    as in Washer timer? (am I right that the Washer Timer includes a new timer motor with it?)
    Jul 2006
    Correct
  1. Maytag A712 timer?
    By moparmutt in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 10th, 2011, 10:41 AM
  2. [FIXED] Maytag washer - Bad timer?
    By Nelson in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 29th, 2010, 07:07 PM
  3. I need just a motor for a timer not the whole timer
    By jmundt2 in forum Sears Kenmore
    Last Post: May 3rd, 2010, 10:56 PM
  4. Maytag dryer won't start, motor humming and timer button cannot be pressed down
    By BenChang in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 15th, 2005, 08:00 PM
  5. Where can I find a Kenmore Washer timer motor?
    By tombilliodeaux in forum Sears Kenmore
    Last Post: March 21st, 2005, 08:18 PM
