Old March 22nd, 2006, 01:45 PM
BennyPrimo is on a distinguished road
Default trouble shooting fan for MTB1956GEQ
Hello!
First time posting, fan stopped working. Before purchasing new part, any thing I should be doing to isolate problem to make sure fan motor is burnt out. Thanks for any help!
Old March 22nd, 2006, 03:08 PM
I should have mentioned that the fan was sputtering and was making noise also before it died out.
Old March 22nd, 2006, 10:52 PM
Sounds like the bearing went out on it, you can get a volt meter and see if its getting 120 volts to the fan motor, if 120 volts is present, then your fan motor is shot.
Which fan motor is it, the freezer(evaporator) or condenser fan motor?
Whats the serial#?
Old March 23rd, 2006, 09:55 AM
Hi Jake,
The fan in the freezer, have to buy new tester. Darn thing is so old, it has a bad fuse I believe. Going to off to buy one now. Thanks for your speedy reply Jeff!
Old March 23rd, 2006, 09:59 AM
forgot to reply to part # request. the part is in transit, will follow up after I test voltage and my old man gets back with the part.
Old March 23rd, 2006, 12:51 PM
Ok, sounds good.
Old March 23rd, 2006, 02:14 PM
Doesn't seem to be giving any juice, tested voltage meter and it works properly.
Inserted red prong into female receptor and black prong to the coils in back of freezer to ground. Want to make sure I am doing this properly.
Fan motor part # UDQR002MGL
Old March 23rd, 2006, 11:31 PM
Put the leads in the complete receptor, 1 on each side.
Old March 24th, 2006, 07:46 AM
Meter lit up quite nicely
YOU'RE THE MAN, Jake!
Going to order new motor, i best have rush delivered. I saw some racoons outside the fence plotting on my stash.
Old March 24th, 2006, 12:29 PM
Thats good you have voltage to it, that motor will take care of it.
That fan motor part# UDQR002MGL didn't show up, was there another part# that you ordered by?
Condenser Fan Direction thornyschizoid Refrigerators & Freezers 1 April 27th, 2008 02:46 PM
MTF2156GEW - Evap Motor Fan bad - twice in two years MadSalad Maytag/Magic Chef/Admiral/Jenn-Air 10 November 17th, 2007 01:57 PM
Kenmore Coldspot Condenser Fan? Bambachic Sears Kenmore 7 July 17th, 2007 09:57 AM
Maytag MTB1956GE Condenser fan CPG208 Maytag/Magic Chef/Admiral/Jenn-Air 10 April 18th, 2007 06:05 AM
Fan turning slowly but freely?!? Help! dmiller12 Window & Room Air Conditioners 3 August 10th, 2005 06:00 AM
