Old April 12th, 2006, 07:59 PM
lobsterek is on a distinguished road
Default Maytag frig lights off
Hi, I need advise on how to diagnose the following problem, the two lights inside the frig just stop working ( should be on when you open the door ?)
do not believe i have probem with the two light bulbs at the same time . The freezer is working thought ....Please provide some pointers ..Thanks
Model number MTB1956GEW
Thanks Ernest
Old April 12th, 2006, 09:37 PM
Bad switch, bad socket, broken wire ( rare ) or two bulbs failing/loose at the same time will make both lights go out at the same time.
Some tips are linked here to test the light switch.
Light switch
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old April 14th, 2006, 01:54 PM
Hi Jeff,
I took the switch out ,continuity test ...passed ,remove two light bulbs ..test again with my table lamp ..both works ..what should I do now .. .. the fan in the freezer is working ......not sure how the frig works , somone told me " as long as the freezer is working that should be ok ..becasue the cooler get the "cold" from the freezer" ..but now my cooler is not as cold as before ...what shoud I check now ...Please advise Thanks
Ernest
Old April 14th, 2006, 03:03 PM
*Carefully* check for power at the bulb socket....the socket will come out and have 2 wires going to it....power there and the bulbs are ok = bad socket....no power there = bad switch or broken wire in the cabinet.
Won't effect the lights.
A new problem
http://www.repairclinic.com/referral.asp?R=153&P=46
http://www.applianceaid.com/common_frig_parts.html
JRAppliance
Maytag quiet Series 100 lights come on won't start LogLew Maytag/Magic Chef/Admiral/Jenn-Air 2 May 25th, 2007 11:03 AM
Maytag Dishwasher MDB6100AWW blinking display lights and won't run? chip718 Maytag/Magic Chef/Admiral/Jenn-Air 1 May 10th, 2007 10:43 AM
Maytag Dishwasher lights blink, won't cycle Jboz Maytag/Magic Chef/Admiral/Jenn-Air 1 December 12th, 2006 01:10 AM
Maytag Dishwasher Blinking Lights lccow Maytag/Magic Chef/Admiral/Jenn-Air 5 February 19th, 2006 02:35 PM
Maytag PTB2154GRW no Frig or freez cooling jbikeman112 Maytag/Magic Chef/Admiral/Jenn-Air 8 November 1st, 2005 04:00 PM
