Old April 25th, 2005, 11:00 AM
Jason88 is on a distinguished road
Post imported post
Hi, my 18 months old Maytag Refrigerator MTF2156GEW does not stop running. This could be my fault, but I'm not sure. What happanned was: my refrigerator has been making some cracking noises occasionnally, so my wife looked around in the fresh food section(this model's freezer is on top) and found some foam plastics(like the type used for packaging things) in a box-like part mounted on the ceiling of the refrigerator. From the user's manual that box-like part appears to be the vent through which the cold air from the freeze on top blow into the fresh food section below. I tried to remove the foam plastics but they were stuck, so I ripped several pieces off hoping they would just fall off, but they didn't and I gave up. Ever since that happanned, which was yesterday afternoon, the refrigerator has been running constantly with only a half an hour stop last night. Does anyone know if those foams were supposed to be there? It's too much of a coincidence that the frige now runs constantly after I ripped some of it out. Thanks in advance.
Old April 25th, 2005, 12:26 PM
Post imported post
**Does anyone know if those foams were supposed to be there?**
Yes!
**It's too much of a coincidence that the frige now runs constantly after I ripped some of it out.**
Does sound like this effected the air flow and control cycling Temps are still ok?
#11 in the pic above, Damper/insulation kit for MTF2156GEW
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old April 25th, 2005, 01:05 PM
Post imported post
Thanks, Jeff. Is this something I can install myself or do I have to call in a technician?
Old April 25th, 2005, 01:07 PM
Post imported post
Forgot to say, temp is still OK, since it's running constantly. I'm just curious about how the airflow was affected. Is it because the warmer air from the fresh food section is flowing back to the freezer due to the openned hole from the ripped foam, thus causing the temp in the freezer to go up?
Old April 25th, 2005, 05:19 PM
Post imported post
**Is this something I can install myself or do I have to call in a technician?**
Yes.....no. Not difficult to do, but the entire control assembly that is screwed to the FF section ceiling comes down, off and out to replace the part(s).
**I'm just curious about how the airflow was affected**
We are more going by your "this occured after I tried to remove the foam" problem. Both air intact and exhaust is done in that area, warm air is sucked up inside the freezer and cold airis blowndown from that area ( 2 seperate vents ).
Never hurts to check/clean the consensor coil under the refrigerator as well.
JRAppliance
Old April 25th, 2005, 06:03 PM
Post imported post
So it's possible that the warm and cold air is crossed preventing the FF section's temp to fall low enough to turn off the frige? I'll try to replace it myself, hopefully without breaking anything else. Thanks.
Old April 25th, 2005, 06:07 PM
Post imported post
BTW, I ordered the part and it's arriving in 2 days. Do you think the frige will be damaged if I leave it running like this for 2 more days? Or should it be turned off until it's fixed? Thanks again.
Old April 25th, 2005, 09:01 PM
Post imported post
The fridge is -capable- of running a lot and won't be harmed....but if you have a second unit to put all your food into and turn off that one until it is repaired, sure do that.
JRAppliance
MAYTAG MODEL NUMBER MTB1894ARW - sounds like its always running? carolanne Maytag/Magic Chef/Admiral/Jenn-Air 9 October 21st, 2006 12:20 PM
Maytag model WU702 Dishwasher - NOISY Mark Gammell Maytag/Magic Chef/Admiral/Jenn-Air 2 August 11th, 2006 09:54 PM
Maytag Dryer won't stop running. mrstree Maytag/Magic Chef/Admiral/Jenn-Air 6 June 28th, 2006 11:20 PM
Kenmore Model 110.66822694 Won't Stop Running hunter6009 Sears Kenmore 1 March 6th, 2006 12:22 AM
Kenmore Electric Dryer Won't Stop Running WadeB Sears Kenmore 2 December 7th, 2005 08:46 PM
