Old May 4th, 2006, 05:49 PM
eov eov is offline
eov is on a distinguished road
Default My fridge is broke, help!
Okay so I tried searching for my model but couln't find it. Its a Maytag MSD2651HEW which we bought in April of 05, so that means the warranty is expired?! So the problem is than I can hear the fridge running but it's really hot inside. If you guys need more info please ask! I hope this won't cost much!
Old May 5th, 2006, 12:40 AM
Its blowing hot air in the freezer, where it should be cold air? If thats the case, your compressor is running backwards, and it will need to be replaced. You have a 5 yr. full parts and labor warranty on that.
Jae
Old May 5th, 2006, 11:14 PM
jmshaffer is on a distinguished road
Most likely a defrost problem or a light switch not closing leaving a bulb on.
Do you see frost on the back panel of the freezer? If so, this suggests a defrost condition. Give us more information...temps in both sections etc...and make sure doors are turning lights off when they contact the switch by pulling back slightly on the gasket after door is closed to see if you notice any light inside.
If no cooling at all...you might need a compressor.
Old May 12th, 2006, 09:36 AM
eov eov is offline
Well everything inside seems to be cool, but whenever the ice maker produces ice, it then just melts and water drips out.
Old May 12th, 2006, 01:55 PM
Very interesting, I will give you a couple of links that should help:
Applianceaid
RepairGuru
Old May 12th, 2006, 08:12 PM
eov eov is offline
Well I found out that the the refrigerator part is getting really cold, like I found my lettuce frozen this morning! But the ice still melts when it sits in the bucket.
Old May 12th, 2006, 11:08 PM
weird one...I'd check to see if your light is staying on in the freezer when door's closed possibly, or maybe your air damper is not closing when it should?? unusual problem you have.
Old July 30th, 2006, 11:28 AM
lokring is on a distinguished road
sounds to me like the evaporator fan may have failed if the freezer is freezing in the bottom i would expext the fan behind the back wall of the freezer is jammed or failed this is located behind the centre internal back panel...........good luck i know the maytag range quite well so im here if i can help...good luck
Kenmore Bottom-Freezer Fridge Icing up in Drainpan Hondatudinal Sears Kenmore 3 September 18th, 2007 08:46 PM
Hotpoint fridge cooling issues rvnforfun GE/Hotpoint 5 June 27th, 2007 10:57 AM
GE fridge not to cold and making gurgling noises and shuts off when moved. oopsydaisy GE/Hotpoint 3 April 26th, 2007 11:27 AM
Jennair fridge side not cold after defrost wobbletop Maytag/Magic Chef/Admiral/Jenn-Air 7 September 20th, 2006 01:48 AM
msd2465ge - Fridge side not cooling MarkF2 Maytag/Magic Chef/Admiral/Jenn-Air 6 August 31st, 2006 12:43 PM
