Old May 11th, 2006, 08:24 PM
braindead is on a distinguished road
Unhappy Maytag MZD2766GE Ice Dispenser Problem
I have a Maytag MZD2766GE refrigerator and the automatic ice maker water supply line freezes solid. Specifically, it freezes in the supply line from where the tube enters the freezer compartment to the icemaker where the tube terminates. Two repairmen have come out, cleaned the supply tube, insulated it, and adjusted the icemaker but it still continues to freeze solid.
Help! Any suggestions would be appreciated. Thanks.
Old May 11th, 2006, 08:32 PM
Default Additional note
By the way, the fill tube is insulated and has a slit lengthwise down the top of the tube.
Old May 11th, 2006, 09:48 PM
First I would check your water supply line to the refrigerator by pulling it away from the wall and making sure you have good water pressure on that line.
If its good pressure, then I would say your water inlet valve is bad.
Old December 8th, 2006, 10:09 AM
Thank you very much for your response. We finally ordered and replaced the water inlet valve and it has worked perfectly since. Thanks again.
Old December 8th, 2006, 11:41 AM
Good job fixing it braindead, glad its back to normal again.
*Another* Maytag ice maker problem robmarz Maytag/Magic Chef/Admiral/Jenn-Air 5 April 19th, 2007 10:05 AM
Maytag MSD2556AEW Ice dispenser comes on by itself lumburgfdher Maytag/Magic Chef/Admiral/Jenn-Air 5 February 9th, 2007 09:50 PM
Maytag Water Dispenser problem kherbold Maytag/Magic Chef/Admiral/Jenn-Air 3 January 15th, 2007 10:09 AM
Maytag Refrigerator Ice dispenser flap not opening casketkahuna Maytag/Magic Chef/Admiral/Jenn-Air 2 January 4th, 2007 12:43 AM
Ice Dispenser Problem Model FRS26H5ASBS tampapi Frigidaire/Electrolux 9 August 18th, 2005 05:58 AM
