Old May 16th, 2006, 09:22 AM
gigimarie is on a distinguished road
Default Maytag dryer won't heat
I could not get my Whirlpool gas dryer to heat so I bought a new Maytag gas dryer (Model # MDG7658AWW). It worked great for about a week but now does the same problem my old dryer was doing. It runs but will not heat. The gas line is on. Sounds like a gas line problem to me or maybe a fuse or breaker and not a dryer problem since both dryers would run but not heat. Any suggestions?
Thank you~
Old May 16th, 2006, 11:44 AM
Has the venting and vent hood been cleaned out lately?
It runs but will not heat - It worked great for about a week
Still under warranty? If yes, call for a warranty service call.
A copy:
Q - My gas dryer will not heat, what could stop my dryer from heating ?
A - Things that could stop a gas dryer from heating:
- glow bar igniter ... - thermal fuse( not all models! ) ... - coils on the gas valve ... - gas valve ... - thermostats ... - motor heat switch ... - timer ... - selector switch ... - sensor ...
A page for checking gas dryers is here.
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old May 16th, 2006, 02:40 PM
Default Maytag won't heat
All venting was cleaned completly when we replaced the old one with the newer dryer just recently. I bought the new dryer from a friend so no warranty. It's about 3 yrs. old. I'm guessing a gas line problem since both dryer would run but not heat...
Old May 16th, 2006, 06:12 PM
Or a big coincidence since the Maytag worked for a while.
Local gas conpany can check the line/pressure for you.
JRAppliance
Old May 16th, 2006, 07:07 PM
Thanks! I'm going to call the gas company tomorrow.
Maytag dryer trips breaker when turned on heat cycle miketharris Maytag/Magic Chef/Admiral/Jenn-Air 2 January 28th, 2007 10:24 AM
Maytag Gas Dryer, will not heat bobbyboy Maytag/Magic Chef/Admiral/Jenn-Air 6 September 17th, 2006 08:35 PM
Maytag Legacy Electric Dryer --> Popped! Now, No Heat? sundance Maytag/Magic Chef/Admiral/Jenn-Air 3 August 24th, 2006 07:47 PM
Maytag Electric Dryer DE482 does not heat jumpu Maytag/Magic Chef/Admiral/Jenn-Air 1 February 2nd, 2006 12:49 AM
New Maytag dryer won't heat justcoop Maytag/Magic Chef/Admiral/Jenn-Air 1 August 12th, 2005 02:20 PM
