MSD2456GE - We started to get water intermitently from the freezer, in addition we would get a build up of ice on the bottom of the freezer. I would go through the drill of removing the ice and melting the ice over the drain hole using a hair dryer and hot water. I also shut off the water supply to ice maker. Unfortunately the rate of water and ice leaking seems to be speeding up (could be because of the warmer weather). Also I recently noticed a build up of frost through out the rest of the freezer which I never noticed before. What should I be testing/replacing next? Thanks in advance for your help |
![]() Door not closing properly, ice dispensor door staying open are common trouble makers. http://www.applianceaid.com/frig_leaking.html jeff.
Jeff thanks for the reply
On the sticker on the door it says MSD2456GE*, should I look somewhere else? The water leaks out onto the floor, plus there is a build up of ice on the floor of the freezer engulfing the bottom bin. The drain keeps freezing up, I keep thawing it out with heat and hot water and within a few days I have an inch of ice on the bottom of the freezer and water dripping out onto the floor. I'll check the ice/flap. Where does the water go from the defrost bin? Does it just evaporate into the kitchen? |
http://www.applianceaid.com/model.html Quote:
| Maytag Freezer leaking water | RNS | Maytag/Magic Chef/Admiral/Jenn-Air | 5 | May 21st, 2007 09:49 AM |
| GE Profile water dispenser line leaking | dlynch | GE/Hotpoint | 4 | October 4th, 2006 07:17 PM |
| water leaking from top of freezer GE side by side | Norman | GE/Hotpoint | 1 | August 15th, 2006 09:17 AM |
| GB8SHK - ice on bottom of freezer and unit is leaking water from front | lily99 | Whirlpool | 1 | July 20th, 2006 08:51 PM |
