I posted in this category because I believe that Roper is part of the Maytag family. My Roper refridgerator is leaking water and freezing in the "fridge" area. The leak is coming from the upper "wall" and flooding the top shelf of my fridge area. I haven't begun taking anything apart yet but I was hoping that someone could shed some light before I tear into this one. Am I most probably looking for a clogged line, bad thermostat, ect? First time poster here, please forgive any irregularities in my questioning.
Thanks, Chad |
No model number, but sounds like a freezer on top with a clogged defrost drain. http://www.applianceaid.com/frig_leaking.html#inside Some things to check. |
thanks Mac. Never worked on a fridge before but I'm technically inclined enough to wade through it. I'll give it a look and if I get stumped, I'll be back w/ some model #'s for ya! thanks again!!
Chad |
Got brave enough to pull everything out and start looking. After I removed the bottom tray to the freezer, my problem was evident. 1/2 inch of ice and as you figured the defrost drain was frozen shut. Cleaned everything out and it's doing great now. If this continues to happen, do you have any insight as to why the freeze occured in the first place?!? Thanks again!!
Just one of those things. Whirlpool have a kit to deal with this kind of issue, I've found it very successful:
http://www.applianceaid.com/defrost_drain_freezes.html Basically, a little probe to get some heat into the drain. Comes with instructions. |
Thank you very much Mac. I'll definitely be sharing this forum with anyone that could use it. Once again, thanks for all your help.
| Roper - 4 prong plug to 3 conversion - Help! | perserd | Whirlpool Brands Forum | 0 | March 7th, 2007 07:52 AM |
| Roper Dryer Starts only runs five seconds | stewill | Dryers | 5 | February 17th, 2007 01:15 AM |
| Roper (Whirlpool) RAX4232KQ0 Washer Won't Drain or Rinse | Josh1001 | Whirlpool/KitchenAid | 3 | October 1st, 2006 06:20 AM |
| Roper no spin or agitation | JohnBailey | Washers | 8 | September 13th, 2006 09:21 PM |
| Roper micro dead? | arizonie | Whirlpool/KitchenAid | 4 | August 29th, 2006 07:24 AM |
