  #11
Old June 30th, 2006, 12:33 PM
Yes, it sounds like your evaporator fan motor is bad.
Whats the serial# of your refrigerator?
Old July 3rd, 2006, 02:08 PM
jerobi is on a distinguished road
Success.
I yanked everything out, took the ice maker and back plate off, and checked the fan. I got a 120V on the fan supply, but the fan didn't register any continuity. I tried some bare wires from an outlet (both directions) and it didn't move. After the fun of getting that air funneller and fan bracket off, I again plugged it into some bare cable from an outlet, and to my surprise it spun up. It must have been jammed and removing the motor from the mount must have jarred something loose.
I took the opportunity to look down the slot to the fridge and I'm pretty sure the damper is stuck open. But that's another project. I'll be satisfied if things cool down and I see some ice in the ice maker tomorrow.
Thanks again.
Old July 3rd, 2006, 07:20 PM
Perhaps that was premature.
It again seems like the evap fan doesn't run. I just spun the timer a bit and cycled the fridge power. The compressor came on, but the fan isn't moving.
I guess I'll take it apart again tomorrow morning. My only thoughts on the cause:
1) Quirky fan motor
2) Detatchable center air venting cover too tight, maybe preventing fan from turning
or, 3) Fan freezes up when it gets cold. Anyone ever run into that?
Old July 3rd, 2006, 07:27 PM
MTB2156GEW Fridge
Wow, I didn't realize those rubber gromets were part of the spinning section. I think that could definitely be an issue. Horrible design if that's the case - I'll confirm tomorrow.
Old July 4th, 2006, 02:20 AM
Yes, a new evaporator fan motor should fix it for you.
Whats your serial# on your refrigerator?
Maytag Model MSD2657HEQ fridge side warm robivi3 Maytag/Magic Chef/Admiral/Jenn-Air 5 June 9th, 2007 03:29 PM
Kenmore 106.72852101 Water in fridge, warm fridge robss96dcm Sears Kenmore 3 June 5th, 2007 12:06 PM
GE bottow freezer; fridge is warm askimbo GE/Hotpoint 1 March 1st, 2007 06:49 AM
Maytag MZD2766GE Not Cooling Fridge Tanjima Maytag/Magic Chef/Admiral/Jenn-Air 5 November 14th, 2006 05:34 PM
Maytag MSD2356AE leaking water in fridge (not drain prob) kfree Maytag/Magic Chef/Admiral/Jenn-Air 1 July 2nd, 2006 11:38 PM
