Look-Up & Order Appliance Parts Classifieds Shop Home Appliances Appliance Blog Home Appliance News
Bookmark and Share LinkBack Thread Tools Search this Thread Display Modes
Old July 2nd, 2006, 11:30 AM
kfree is on a distinguished road
Default Maytag MSD2356AE leaking water in fridge (not drain prob)
So we've had countless problems with our fridge in the past few years, but we completely replaced everything.. heater, coils, thermostat, control panel in the fridge (sears did, rather)... and the other day, about 4 days ago, I noticed water accumulating on the top tray of the fridge. The filter seemed plugged in fine, so we decided to make sure the drain in the freezer was ok. Poured some water down the drain, drained properly.. wasnt a drain issue in the freezer.
took off the panel in the fridge to make sure everything was ok, seemed fine. TODAY I was just thinking, maybe its something with the waterline... and so I decided to test the water dispenser.. sure enough, you try to get water out of the fridge's water dispenser and the area where the waterfilter is in the fridge... shoots out water. I'm assuming it happens when the freezer is making ice.. so that could be the problem
My question is.. anyone seen this problem? have any solutions? I've removed the filter and i'm still gettin the water squirting out when i hit the water dispenser trigger..
Just curious what I can do, would love a few cold beers for the 4th :P
Old July 2nd, 2006, 09:38 PM
Sounds like you may need the main fitting, secondary fitting or the filter head.
The Repair Manual will help you, if you plan to do it yourself.
Kenmore Coldspot #106.71209100 - Water leaking into fridge reeboblue Sears Kenmore 2 September 12th, 2009 03:45 PM
Maytag MZD2766GE leaking water rziraschi Maytag/Magic Chef/Admiral/Jenn-Air 7 July 1st, 2007 09:49 AM
Maytag MDB5100AWW leaking, won't cycle or drain Chailena Maytag/Magic Chef/Admiral/Jenn-Air 8 April 21st, 2007 11:34 AM
Leaking Water inside fridge (Defrost Drain clogged?) phazerwolf Whirlpool 1 January 24th, 2007 11:11 PM
New Maytag Fridge, water dispenser not working. minskore Maytag/Magic Chef/Admiral/Jenn-Air 1 October 29th, 2006 08:09 PM
Powered by vBulletin® Version 3.8.5
© Applianceblog.com 2004 - 2010
