Results 1 to 10 of 11
Thread: Maytag Performa Dryer Won't start
    cheapkelly is offline Member
    Jul 2006
    MI
    Default Maytag Performa Dryer Won't start
    First, I want to tell you how greatful I am for this site. I googled and come across TONS of troubleshooting, but nothing really helped. The dryer problem started about a month ago. Sometimes after a load or two, it wouldn't start, so we just let it cool down and it worked fine. Now it hums when trying to start. Hubby took it apart, cleaned everything, etc. He told me that if the start button is pressed in and he turns the drum by hand,it'll start. Please give advice on what else to check. I would appreciate it!!
    Pegi at Sams is offline Appliance Tech
    Oct 2005
    Wichita Falls, Texas USA
    Sounds like you have a bad motor, either bearings or the start windings are bad...suspect you would need to replace this motor...
    Jul 2006
    MI
    OK, hubby "turned it' with his hands and I pressed start at the same time. It worked for about 2 minutes, then stopped. But.........get this. The timer moved from 80 minutes to around 40, which is the time it took between to hear the "click" again. Does this seam normal? Is there any way to check the motor to see if it's bad? I know he turned it with his hand and he said it was an easy turn (if that was the motor)
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    Unhappy
    You have a bad motor.I would say 7 out of every 10 Maytag Performa's I get in my shop have bad motors.
    Jul 2006
    MI
    If we do it ourselves, how much does the part itself run? Is it pretty easy to change it yourself if you're pretty handy????
    Jul 2006
    If your pretty handy its not hard to do.The hardest thing will probaly be getting the belt back on the idler pully. Before you invest $125+ I would price some new dryers(or used). The Maytag Performa is actually a norge style dryer.Now days just because it says Maytag dosen't mean it wasn't designed by someone else like Norge or Admirial.
    Jul 2006
    MI
    Hubby took the front off and a few other things. Do you have to take the drum out to get to the motor??? If not, can you send a diagram to show us how to get to the motor?? Thanks!!
    Oct 2005
    This should help you with taking the dryer apart...
    Jul 2006
    MI
    The links don't appear to work. This is a dumb?? but does the drum need to come out????????????????????
    Jul 2006
    Yes, the drum and front shroud have to come off.There is two screws holding the motor plate.Remove these screws and the motor, blower, and idler pully will come out as an assembly.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  1. Maytag Performa won't start, only buzzes
    By pieland in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 20th, 2007, 07:02 PM
  2. Maytag dryer will not start
    By reverend saveabuck in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 18th, 2007, 09:12 AM
  3. Maytag Dryer Performa Dead
    By JohnA in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 19th, 2007, 02:34 AM
  4. Maytag Performa Dryer Sqeaking
    By crpeddler in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 3rd, 2006, 11:01 AM
  5. Maytag Dryer LDE7304ACE, won't start
    By dorton in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 31st, 2006, 01:20 AM
