Old May 22nd, 2005, 09:07 AM
gmv gmv is offline
gmv is on a distinguished road
Post imported post
My Maytag top loader (model # LAT8705AAE) leaks during the final spin cycle. This washer is problably ~10 years old, but i'm not totally sure because it came with the house when I bought it.
I had the same problem about a year ago and I fixed it by cleaning up the tub gasket. However, it started leaking again a week ago so I cleaned up the gasket again and actually replaced the gasket. But it still leaks...
After I installed the gasket I discovered that some repair websites sell silicon sealant. Do I need to use silicon selaent when I replace the tub gasket?
The leaking is not too bad. If I buy a washer tray, can I just live with the leak? Could my washer short out and cuase a fire?
thanks
Old May 22nd, 2005, 11:19 AM
Post imported post
**The leaking is not too bad. If I buy a washer tray, can I just live with the leak?**
Water and electrical parts = bad!!
**Could my washer short out and cuase a fire?**
Fire, probably not, electrical short, yes.
**My Maytag top loader (model # LAT8705AAE) leaks during the final spin cycle**
Open it up and leave the front panal off, baby sit a load or two and see if youcan ID where the water is comming from.
**Do I need to use silicon selaent when I replace the tub gasket?**
Not normally, but is the outer tub is a bit rusted on the edge, a little doesn't hurt.
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Maytag Freezer leaking water RNS Maytag/Magic Chef/Admiral/Jenn-Air 5 May 21st, 2007 11:49 AM
maytag refrigerator leaking slls Maytag/Magic Chef/Admiral/Jenn-Air 5 November 9th, 2006 12:29 AM
MAYTAG MODEL NUMBER MTB1894ARW - sounds like its always running? carolanne Maytag/Magic Chef/Admiral/Jenn-Air 9 October 21st, 2006 12:20 PM
Maytag Performa leaking when filling soaked Maytag/Magic Chef/Admiral/Jenn-Air 4 July 25th, 2006 09:14 AM
Leaking Maytag top Load Washer maroonedinnj Maytag/Magic Chef/Admiral/Jenn-Air 1 December 22nd, 2005 11:46 AM
