Old August 16th, 2006, 01:28 PM
mamtech is on a distinguished road
Angry Maytag S/S refrigerator (MSD2756DEW) is not cooling properly:
Problem: Initially the refrigerator would slow down the cooling process and I notice water under the lower crisper pan. Also, I stop hearing the "click-click" noise which probably indicates that the auto-defrost is not happening anymore. After a day or 2 the refrigerator would give up completely and after 3 to 4 days, the ice-cream is the freezer section would start melting. This is followed by lot of ice formation on the lower back wall of the freezer.
My temporary fix: Power down the refrigerator for 24hrs and let all the ice melt down. Clean up everything and connect the power supply. After 24hrs, things are restored back to normal and I start hearing the click-click noise about 4 - 6 times a day. The above mentioned problem re-occurs after 5 to 8 weeks.
Question:
- Is the auto defrost system broken ?
- If so, why does is function normally for few weeks before giving up ?
- We are suspecting that a partially opened door for a prolonged period of time is throwing off the auto defrost timer or thermostat or whatever. Could this be true ?
Please let me know,
_Mamtech
Old August 17th, 2006, 10:43 AM
After you unplug it for 24 hrs. the frost melts from the evaporator coil, then it could cool fine for awhile, but with a bad/intermittent defrost board, it will do the same thing.
A partially opened door would case frost on everything, not just the lower back panel inside the freezer.
Sounds like you need a new defrost board as noted in this thread:
http://www.applianceblog.com/mainforums/showthread.php?t=223
[FIXED] Maytag Refrigerator Model MSD2756DEB is not cooling properly suk Maytag/Magic Chef/Admiral/Jenn-Air 249 June 8th, 2009 12:57 AM
maytag xrss287bb not cooling properly heater satying on goza21 Maytag/Magic Chef/Admiral/Jenn-Air 3 March 16th, 2007 10:31 AM
Maytag PTB195LGRW not cooling rocksguy Maytag/Magic Chef/Admiral/Jenn-Air 2 August 9th, 2006 11:36 AM
Maytag Model MSD2732GRQ clicking noise/not cooling properly nova817 Maytag/Magic Chef/Admiral/Jenn-Air 1 November 26th, 2005 06:01 AM
