Old August 19th, 2006, 11:51 AM
batterup is on a distinguished road
Default Jennair FrenchDoor Refridge beep/chirp noise
Every two minutes, makes a beep like sound, similar to a chirp, almost sounds like a cricket - help what is it? operating for 10 months, seems to be working well otherwise. making us crazy!
Old August 19th, 2006, 03:00 PM
Model#?
Think the noise is more noticable inside the refrigerator or outside of the refrigerator?
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old August 19th, 2006, 03:17 PM
Hi Jeff,
No noticable difference when open or not. sound is the same.
Model number is P jfC2089HPF. Any ideas for us?
Thanks.
Old August 19th, 2006, 10:45 PM
That is going to make finding the trouble maker tough....can't tell if the noise maker is inside or outside of the cabinet/refrigerator.
Tubing rattling, fan motor(s), motorized damper, control board, icemaker can make noises
Probably will have ot follow your ear towards the trouble maker.
JRAppliance
Old August 20th, 2006, 03:49 PM
Default Louder when doors are closed
Hi Jeff,
I stuck my head inside the frid to see if it was louder when doors were open, it seems not. It seems like I can hear it better when my head is not inside the fridg.
does that make any sense to you? FYI, we don't have the icemaker etc hooked up at all, so I know it's not that! Any other suggestions? tx very much.
Old August 17th, 2007, 06:25 PM
jskos is on a distinguished road
Default Same Issue
I have the same fridge and the same issue (oh joy). The sound seems to be coming from the fan assembly (at least I'm assuming this is what it is) in the center, top, back of the fridge. Behind a white plastic cover. Cold air is blowing out of this cover.
A small fan belt or something??
Please let me know if you figure it out!!
UltraWash 665.15835793 Noise & Not Circulating Water Echous Sears Kenmore 4 August 26th, 2006 10:19 AM
New Freezer Noise (253.26762100)- Need Repair? TigardUser Sears Kenmore 2 June 17th, 2006 10:46 PM
Kenmore 580.74054400 Coolant noise MetalCastr Window & Room Air Conditioners 2 May 6th, 2006 11:10 AM
High pitched whining noise Kenmore refridge wat4 Sears Kenmore 5 April 9th, 2006 04:09 PM
JennAir SxS vibrating noise jennairguy Maytag/Magic Chef/Admiral/Jenn-Air 5 June 15th, 2005 12:13 PM
