Results 1 to 4 of 4
Thread: Maytag Legacy Electric Dryer --> Popped! Now, No Heat?
    sundance is offline Member
    Aug 2006
    Virginia
    Default Maytag Legacy Electric Dryer --> Popped! Now, No Heat?
    Have a two year old Maytag Legacy series electric dryer I purchased from Home Depot. Was running the dryer last night, and heard a large pop sound. Today, I discovered that the dryer no longer heats, but otherwise appears to run normally. I can also smell a distinct electrical burn smell when the dryer is running.
    Is this likely due to a bad electric heating element? How to you get access to this heating element? Any other possibilities? Thanks.
    Oct 2004
    Cute names....but not a model#.
    http://www.applianceaid.com/model.html Some model# helps.
    A copy:
    Q - My electric dryer runs but will not heat, what could stop my dryer from heating ?
    A - Things that could stop a electric dryer from heating:
    - house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug ...
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Aug 2006
    Virginia
    Default Maytag Dryer Model No.
    The model no. is: SDE515DAYW
    Oct 2004
    SDE515DAYW
    An Amana built Maytag....some take apart helps....
    http://www.applianceaid.com/may-apart2.html
    JRAppliance
  1. Maytag Legacy series dryer walks
    By Jann K in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 3rd, 2007, 07:41 PM
  2. GE Electric Dryer runs but no heat
    By vdrsolo in forum GE/Hotpoint
    Last Post: September 27th, 2006, 01:44 PM
  3. Maytag dryer won't heat
    By gigimarie in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 16th, 2006, 06:07 PM
  4. Maytag Electric Dryer DE482 does not heat
    By jumpu in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 1st, 2006, 11:49 PM
  5. Kenmore Elite electric dryer no heat...
    By route62 in forum Sears Kenmore
    Last Post: January 10th, 2006, 03:40 PM
