Results 1 to 7 of 7
Thread: msd2465ge - Fridge side not cooling
    MarkF2 is offline Member
    May 2006
    LI, NY
    Default msd2465ge - Fridge side not cooling
    Fridge side is not cooling, freezer side works fine but I noticed lots of frost.
    Not sure if this is related or not, but I came home a few days ago and I noticed the freezer door was not shut properly. Everything in the freezer already started to melt. I closed the door and few hours later the freezer was working fine. 2 days later we noticed the fridge side not cooling properly. prior to this I noticed lots of ice forming on the top shelf by the freezer vent. Needless to say as the fridge stopped working the melting ice from the top shelf puddled out onto the floor.
    Tonight (the fridge stopped working last night) I checked the freezer coils and sure enough everything was frozen over. There continued to be a build up of frost inside the freezer. Anyway, removed the buildup of ice from the coils inside the backof the freezer (the coils above the water drip tray) and I have not noticed any improvement on the fridge side. I used a blow dryer on the freezer cois and on the fridge side (above the top shelf by the lights).
    My other observation is that I feel a good vacuum seal on the door on the freezer side but not on the fridge side.
    What do I need to do next?
    May 2006
    LI, NY
    Sorry it is 2456
    Your model has the regular defrost timer, not the adaptive defrost control board.
    Check this link to help you troubleshoot it:
    May 2006
    LI, NY
    Thanks.
    Just a quick update - We went away for 3 days, and I did nothing other then defrost the freezer coils with a blow dryer before I left.
    When we came back the fridge was cold, there was a pile of snow on the top shelf of the fridge and water was dripping from the ceiling of the fridge side.
    Are of these still consistent with the defrost timer?
    Thanks again.
    Yes,
    But you would have to test to see what part is out as described in that link I gave you.
    May 2006
    LI, NY
    Got it thanks. I'll try to test it tonight.
    Ok, sounds good.
  1. Kenmore (106.56532400) fridge side not cooling, freezer is,
    By OhNoItBroke in forum Sears Kenmore
    Last Post: June 4th, 2007, 10:30 AM
  2. fix action for my fridge side not cooling
    By akeric in forum GE/Hotpoint
    Last Post: November 21st, 2006, 05:36 PM
  3. Replies: 7
    Last Post: October 27th, 2006, 06:39 PM
  4. Jennair fridge side not cold after defrost
    Last Post: September 19th, 2006, 11:48 PM
  5. GE Side by Side TFX22ZPBG WW No Cooling
    By Richard in forum GE/Hotpoint
    Last Post: June 29th, 2006, 02:57 PM
