Old September 4th, 2006, 02:12 PM
stymied is on a distinguished road
Default Maytag gas range MGR5751BDW
We just took delivery of a new Maytag gas range and the two times we've used the oven the bottom of the food items on the lower rack burnt while items on the upper rack weren't completely cooked. The top rack is in 2nd highest position, the low rack in the lowest position with about 6" between the two racks.
The first mishap was cookies (what a waste of 18 chocolate chip/walnut cookies!),the second instance was biscuits. Both racks had the same type of cookie sheet, oven wasn't crowded, etc. We've looked for an adjustment in the lower part of the oven but we can only find a flame adjustment for the broiler unit located in the top of the oven.
Being a newbie to blogs, I find this format interesting and spent some time looking at other posts. What a great way to solve problems and share expertise. Thanks for any suggestions/tips/help.
Stymied
Old September 5th, 2006, 05:59 PM
Since its new, I would contact Maytag to have a tech. sent out to look at it. There won't be any charge.
Old September 5th, 2006, 06:57 PM
Thank you, Jake. I also accessed the link you sent. It says if using more than one rack, remove the bottom rack 1-3 minutes before baking time ends. Why doesn't Maytag just install a better way to distribute the heat, like a blower. Well, it's a lesson learned and a bit of trivia I will pass along to anyone considering a purchase. Gee...my 32-year old Tappan range didn't require any extra 'work.'
Anyway...thanks for your quick reply, suggestion and link.
Old September 6th, 2006, 10:04 AM
They do have ovens that have blowers, they are convection ovens, they are about $100-$200 higher in price, but worth it.
If you are within 30 days of your delivery, I would see if they would exchange your range for a convection oven range, if you would like to upgrade to it.
Old September 6th, 2006, 05:14 PM
I called the authorized service dealer listed for this area; today I received a call that they're no longer servicing this part of Texas.
Call me old-fashioned but I think when one purchases new "anything" it should work correctly. This is our second go-round as first-time Maytag consumers. The first range had damage to the side of the appliance yet the box it was crated in showed no damage. That means the merchandise had to be damaged before crating and wasn't noticed although it was a diagonal crease that ran from one side to the other.
Currently, I'm waiting for Maytag to return my call. I'm going to look into your suggestion of a convection oven but believe this appliance should function correctly before it left the warehouse.
It could be worse though. I've read other posts so maybe Maytag would consider mine a minor concern.
Thanks again...
Stymied
Old September 7th, 2006, 09:59 AM
Hope you get it all worked out.
Maytag electric range problems carlos schopenhauer Maytag/Magic Chef/Admiral/Jenn-Air 1 June 14th, 2007 06:31 PM
Maytag Gas Range T1 MODEL mgr5770 majorillin Maytag/Magic Chef/Admiral/Jenn-Air 3 February 28th, 2007 01:10 AM
Maytag Gas Range Not Receiving Electricity Shan Maytag/Magic Chef/Admiral/Jenn-Air 1 November 6th, 2006 10:33 AM
Constant clicking on new GE gas range top cmreds GE/Hotpoint 5 September 15th, 2006 06:45 AM
Maytag Gas Oven - oven startup/popping problems kpd Maytag/Magic Chef/Admiral/Jenn-Air 1 April 11th, 2005 12:37 PM
