Hi All.
This is my first post here. I have an older Maytag LA9700 unit that recently stopped working. I narrowed it down to the closing of the lid -- if I leave the lid open, it will begin filling, etc. But as soon as I close the lid it blows the fuse that is mounted next to the two switches (lid switch and another switch) inside the control panel area. Any ideas? Thanks! --Andrew |
I have seen the lid switch blow this fuse..a short in the switch
Thanks, I'll check it.
I forgot to mention that unit will neither spin nor pump out water at any time ... it will only fill. At any time, if I close the lid, the fuse blows. So, because of this and after looking at the schematics, I figured it might be a fault in the motor, etc. --Andrew |
Here is the part you will need, you can order it here:
Washer lid switch assembly complete with fuse Jake
OK, I'll try that!
Thanks, --Andrew |
BTW , they up the fuse amperage to 4amp on the new switch assembly
I speak the truth . |
Thanks to all!
Replaced the switch panel with a new one (4A fuse, indeed) and it's working fine now. Great! --Andrew |
Glad you got it fixed Andrew, and its working good again.
| double oven blows thermal fuse | janrog300 | Whirlpool | 12 | September 30th, 2007 12:25 AM |
| Maytag washer blows fuse | LI_Stan | Maytag/Magic Chef/Admiral/Jenn-Air | 2 | November 19th, 2006 11:53 PM |
| Maytag Atlantis Lid Switch | JamesAlexander | Washers | 1 | October 23rd, 2006 08:58 PM |
| Can I bypass hi-temp fuse on Maytag Preforma Dryer | dhrodefe | Maytag/Magic Chef/Admiral/Jenn-Air | 2 | August 8th, 2006 10:46 AM |
| Maytag A8650 fill valve fuse? | caldinsikagain | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | June 4th, 2006 07:27 AM |
