Old October 25th, 2006, 09:46 AM
hkseller2000 is on a distinguished road
Default Jenn air icemaker yoke
Help!
Needed new icemaker tray shelf (ice bin sits on this), no problem until I try to install the new tray, the yoke which turns the auger must go through a tiny hole, I have no idea how to remove the yoke from the shaft. It is threaded, but just turns with the motor as I try and remove it.
Thanks in advance.
Model - jcd2289atb
Old October 25th, 2006, 11:56 AM
Ok, these are kinda tricky to get off. You will need to get either a heavy duty screwdriver(think metal shaft) style or some big pliers or channel locks and then tap that coupler off, I can't remember if it is clockwise or counter clockwise to take it off, sorry about that, its been awhile since I did one.
Old October 25th, 2006, 01:30 PM
Thanks for the quick help! There is really no room for channel locks or anything else for that matter. Tried turning with a big screwdriver, but it just turns the yoke and motor. Took the cover plate off and saw yoke spline and gear. That can't be the way to do it, the spline is threaded at the end.
Thanks again
Old October 25th, 2006, 11:19 PM
Ok, Hopefully you will be able to get it off.
Jenn Air SVE47100W Timer Instructions? Leighton Maytag/Magic Chef/Admiral/Jenn-Air 3 May 29th, 2007 11:53 AM
replacing burner jenn air cook top nancy73088 Maytag/Magic Chef/Admiral/Jenn-Air 1 April 18th, 2007 10:38 AM
Problem with Jenn air down draft slide in range. jerr462 Maytag/Magic Chef/Admiral/Jenn-Air 6 January 9th, 2007 11:36 PM
Jenn Air Downdraft Cooktop Replacement mfrank2109 Antique and Retro Appliance Chat 1 October 5th, 2006 11:39 PM
jenn air fridge blowing warm air ribeye35 Maytag/Magic Chef/Admiral/Jenn-Air 6 December 1st, 2004 02:23 PM
