  #11
Old November 4th, 2006, 11:39 AM
bamabigfoot is on a distinguished road
Unhappy
sorry it took so long...the serial# is 17707798Ac rev. 17. There are two different valves, a single valve that the water line connect to that feeds to the water filter. a second line from the water filter goes to a duel valve which in turns feeds to the ice maker and the water fountain. I replaced the duel valve, water pressure still not working.
thanks
Old November 4th, 2006, 09:00 PM
Ok, Thanks,
Its likely the single valve one that feeds to your water filter.
Old November 5th, 2006, 01:35 PM
Smile
I bypassed the single valve that goes to the water filter and connected the water line directly to the duel valve. the water pressure was much better like it was before I started having problems.the link you posted for a replacement, is that the maytag part number?
thanks
Old November 5th, 2006, 10:58 PM
Thats the RepairClinic number, its the same single valve. The part# for it is 61005627
Old November 11th, 2006, 05:14 AM
Smile
it was the water valve.
thanks
Old November 11th, 2006, 09:30 PM
Glad that single inlet water valve fixed it up for you.
Maytag dual inlet water valve Geraldz Maytag/Magic Chef/Admiral/Jenn-Air 7 March 6th, 2007 09:02 AM
Maytag A8650 fill valve fuse? caldinsikagain Maytag/Magic Chef/Admiral/Jenn-Air 3 June 4th, 2006 05:27 AM
Maytag MSD2454GR Side by Side Refrigerator Kent Maytag/Magic Chef/Admiral/Jenn-Air 1 September 17th, 2005 04:22 AM
Wiring for Water Valve Maytag Christine Maytag/Magic Chef/Admiral/Jenn-Air 6 September 6th, 2005 06:14 AM
Bad inlet valve? JoyMc59 Refrigerators & Freezers 4 April 11th, 2005 02:40 AM
