Old October 30th, 2006, 08:39 AM
AFH AFH is offline
AFH is on a distinguished road
Default Jenn Air Wall Oven With Fault Code 1
I have a 1992 Jenn Air wall oven model W131W, serial number 13878402KM.
I am having the following problems: F1 with beeping, usually following a baking period. Oven is not reaching the desired bake temperature even after manually adjusting the temperature the maximum 35 degrees.
I have tested the oven (temperature) sensor and it is about 1110 ohms at room temperature.
From what I have seen, this problem is variously identified as the touch pad, the oven sensor or the ERC (clock).
Any suggestions as what to try or test to narrow the problem to a specific, hopefully single, part?
AFH
Old October 30th, 2006, 11:43 AM
Might help....a copy:
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
    * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old October 30th, 2006, 02:46 PM
AFH AFH is offline
Thanks.
I am running that test now. I say running because it sometimes takes several hours for the F1 and beeping to occur. If it happens, it will probably be at about 1 am again!
AFH
Old October 30th, 2006, 08:09 PM
JRAppliance
Old October 31st, 2006, 03:44 PM
AFH AFH is offline
Over 24 hours on the "test" and no F1 OR beep. Unless there is another suggestion I gUess I will try ordering a toucH pad and see if that will fix it.
AFH
Old October 31st, 2006, 09:31 PM
Sounds right to me....
Touch pad and control panel assembly, white
JRAppliance
Old November 1st, 2006, 03:19 PM
domi49 is on a distinguished road
Will the test work for a Jenn Air Model SCE30600B which exhibits similar symptoms?
(When we cook the oven turns itself off, locks itself closed, and flashes F1 and beeps.)
Old November 1st, 2006, 03:58 PM
Normally yes.
http://www.repairclinic.com/referral.asp?R=153&P=176
http://www.applianceaid.com/fault_codes.html
JRAppliance
Old November 2nd, 2006, 10:09 PM
I disconnect the touch panel and let it run for a couple of hours, the locking and unlocking of the door stop and the F1 plus beeping did not show up, but the fan ran the whole time. So under these condition would the best shot be to replace the touch panel first??
Tnks in advance,
Mr. G
Old November 3rd, 2006, 11:52 AM
Unfortunately is sounds like two problems
If mine, ( will be $ ) I'd go both the key panal and probably the relay board. Fan still running kinda sounds like a relay is welded closed or such.
JMO!
JRAppliance
Jenn Air oven door not closing wakeappliance Maytag/Magic Chef/Admiral/Jenn-Air 4 October 21st, 2008 05:19 PM
Thermador CT230 wall oven - blower starting by itself rlsmith Ranges 4 May 18th, 2007 11:23 AM
Jenn-air wall oven doesn't close & temperature is off laroc Maytag/Magic Chef/Admiral/Jenn-Air 3 April 2nd, 2007 11:14 AM
Jenn Air - Oven locked Petermac Maytag/Magic Chef/Admiral/Jenn-Air 1 March 20th, 2007 05:51 PM
E3 F1 fault code, Whirlpool Wall oven Holleywood Whirlpool 3 January 29th, 2007 11:39 PM
