Old June 15th, 2005, 12:41 PM
mhc mhc is offline
mhc is on a distinguished road
Post imported post
My Jenn-Air JTB2488AE ice maker has a solid block of ice near the ice tray section. The ice isnext tothe divided sections where the cubes are presumably normally frozen, in what seems like a trough about 1" wide that runs the length of the ice maker.
After talking with a Jenn-Air troubleshooter I shut off the freezer and put a hot, damp paper towel around the water inlet inside the freezer to try to defrost any blockage.
I am afraid to try to defrost the block of ice because I am not sure if this would harm the ice maker and/or any timing mechanism. Also, I have not tested whether the water line into the freezer is clogged (a line runs from the water filter to the freezer).
Would very much appreciate any advice.
Turns out that defrosting the water inlet line inside the freezer solved the problem. The ice maker now works; it seems that I didn't give it enough time.
Thanks.
Old June 16th, 2005, 12:22 AM
Post imported post
Glad you got it fixed mhc.
Whirpool Conqest Gold Side by Side Ice Maker Problem tadpole88 Whirlpool 13 September 21st, 2007 12:29 PM
Ice Maker problem???? MNKam KitchenAid 4 May 9th, 2007 01:06 PM
GS5SHAXNB00 ice maker problem truesdaleg Whirlpool 13 February 2nd, 2007 11:31 PM
another Ice Maker problem KC73 Sears Kenmore 1 September 14th, 2006 12:54 AM
Whirlpool ED22DQ/RQ Ice Maker problem Rich46 Whirlpool 5 September 11th, 2005 10:16 PM
