Old November 8th, 2006, 07:40 AM
slls is on a distinguished road
Default maytag refrigerator leaking
Have a Maytag refrigerator Model RTD21A AH71C purchased 1991. Looking in the compartment below the freezer a drain for the evaporator is leaking water into the compartment. I blew out the drain line from the pan with compressed air, and from the top best I could. The drain pan is receiving water so the line is not plugged.
I would like to remove the panel below the freezer compartment and need instructions. Thanks
Old November 8th, 2006, 11:30 AM
This is a very involved process to do. You will need to take off both the doors, take off the middle hinge & metal frame, then that bottom plastic panel will slide out, then your will see the Styrofoam piece on the evaporator, that pulls off, then you will see the complete evaporator, now you can twist the holding brackets on each side of the evaporator #25 here on the top left side image:
http://www3.sears.com/imaging/ImageP...&titleID=00001
Then carefully left the evaporator up, then you will just see the metal drain trough with the hole in the middle. You can also left that metal drain trough pan out completely and get all the ice melted and clear that hole.
If your glass heater that mounts in the middle of your evaporator #27, is broken, you will need to replace it, you can order all the parts I have linked to here in this post.
Now, I used to repair alot of these, and I would see that Styrofoam that the metal drain trough sits on #1 here:
http://www3.sears.com/imaging/ImageP...&titleID=00010
can be completely water logged and soft to the touch, if thats the case, you would need to replace that main Styrofoam block assembly.
Old November 8th, 2006, 11:41 AM
Smile
Thanks Jake, that is just the information I needed.
Old November 8th, 2006, 11:50 AM
Glad to help slls.
Old November 8th, 2006, 11:56 AM
jake I CLK on the foam block link and got a rail.
Old November 9th, 2006, 12:29 AM
Thanks slls, I fixed the link.
Maytag Neptune 8700 repair issues & Maytag Rant. jazzman_q Maytag Brands Forum 14 May 19th, 2009 11:40 AM
neptune mah3000aww rtwerp Maytag/Magic Chef/Admiral/Jenn-Air 10 July 21st, 2007 09:19 AM
Maytag Neptune - No spin cycle fox_1028 Maytag Brands Forum 1 May 24th, 2006 11:15 AM
Maytag- IS YOUR MAYTAG GENUINE? Rick Hansen RPh General Appliance Chat 1 September 14th, 2005 09:06 AM
Maytag Wide By Side - Compressor dies after 11 months pete_nc Maytag/Magic Chef/Admiral/Jenn-Air 4 August 16th, 2005 10:24 AM
