July 25th, 2007, 09:38 PM
#21
Yes, I believe so, Its been awhile since I changed one of these, lets see if another tech. or member can verify this as well.
November 14th, 2011, 03:11 AM
#22
Mzd2766ge
Hello,
I am having the same problem with my refrigerator not cooling on the frig side do I have to remove the ice maker to access the coil and fan?
Thank you
Steve
November 14th, 2011, 10:22 AM
#23
Hi Steve,
Lets first check your defrost thermostat and heater, No you don't need to remove the ice maker.
Remove the back panel from inside the freezer, its #20 and see if the evaporator coils #8 are massively frosted up.
If so Ohm your defrost thermostat for continuity while its still frosty to get a proper reading, should read 0-1 ohm. If the defrost thermostat is not frosty when you ohm it, you will get a high reading.
Here's the defrost thermostat heater assembly for your model:
Manufacturer part number 61006199 is RepairClinic item number 1025806
Put your ohm meter probes in the 2 white wire plastic connections, remember it has to be still frosty for a proper reading. Should read 0 ohms.
Then put your ohm meter probes in the black and middle white wire plastic connections, that will ohm your defrost heater, should read between 11-50 ohms.
Unplug your refrigerator first!
If the defrost thermostat ohms at 0-1 while its frosty, and the defrost heater is between 11-50 ohms then order the adaptive defrost control board.
Here's the adaptive defrost control board for your model you can order here:
Manufacturer part number 61005988 is RepairClinic item number 948430
Watch this video to access/replace the ADC board:
http://www.partselect.com/PartDetail...6&SourceCode=3
November 15th, 2011, 03:02 AM
#24
Thanks Jake,
I checked out the defrost heater and thermostat last night on the heater i got 22 ohms the thermostat was 1 ohms I guess they are ok, but I ordered the ADC board and the heater unit as the frig is 9 years old. I figured it couldn't hurt. My unit was iced up solid.
Thanks for all the help. I figure replacing the heater unit is pretty strait forward and I saw the video on replacing the ADC board so I will let you know how I make out.
Thank you,
Steve
November 15th, 2011, 03:09 AM
#25
Save the old heater. It's still good.
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
November 15th, 2011, 09:19 AM
#26
Ok Steve, sounds good, keep us posted.
November 16th, 2011, 02:25 AM
#27
I replaced the parts last night. I put a thermometer in a glass of water and set the settings to # 6 on both freezer and frig. woke up this morning for work at 4:30 and check frig temp was 38 degrees looks like its working like it should.
Thanks again for all your help, the website is very helpful and saved me $$.
Thank you,
Steve
November 16th, 2011, 09:46 AM
#28
Excellent Steve, good job.
By richard tomasetti in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: June 12th, 2007, 12:18 PM
By Gugerluards in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: December 29th, 2006, 03:54 AM
By Tanjima in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: November 14th, 2006, 03:34 PM
By rocksguy in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: August 9th, 2006, 09:36 AM
By Alf50990 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: March 26th, 2006, 10:39 PM
