Old November 22nd, 2006, 03:41 AM
actionjack is on a distinguished road
Default Jenn Aire dual fuel range VIBRATION
When I built my current house in 2002 I installed the then current version of JennAire dual fuel convertible grill/range. Since day one the machine has vibrated terribly and I speculated the convection fan being out of balance was the cause. 3 warranty service calls never solved the problem (wrong parts twice). I had the previous incarnation of this machine in my previous house that I built in 97 and it never vibrated at all. Everytime the oven is used it drives me bananas while heating to temperature vibrating the whole kitchen. Any help would be appreciated.
Jack
Old August 8th, 2007, 05:14 AM
So no one else has experienced this problem?
Old August 10th, 2007, 11:12 PM
It sounds like your convection fan motor or fan blade is the problem.
Whats the model# of your range? its located either inside the oven door, or behind the storage drawer or bottom access panel on the side frame.
Old August 11th, 2007, 10:25 AM
Jds9860aaw
Old August 11th, 2007, 08:59 PM
Did they change both the cooling fan motor and the convection fan motor?
Here is the cooling fan motor for your model:
Part#74004947 Cooling fan assembly
Here is the convection fan motor:
Part#74011168
Old August 12th, 2007, 03:41 AM
Thanks for the info. BTW I think the vibes only happen during heating and end once the temp is satisfied. I need to double check.
Old August 12th, 2007, 08:57 AM
Yes, I have seen both of there fans that can make that noise if the fan motor bearing is bad, or somehow the motor mounts come loose, or even if the fan blades somehow get out of alignment and wobble bad.
Old August 28th, 2007, 08:14 AM
I can definitely confirm it is the fan inside the oven. This fan only works during bake and until the temperature is satisfied. I may try to replace it myself. It does seem visually to not spin true. I believe it was replaced once under warranty with the same result.
Kenmore Elite Dual Fuel Model 790.7921 F1 ERR jterrell Sears Kenmore 0 April 30th, 2007 02:23 PM
Kenmore Gallery Slide-in Dual Fuel Range wclyffe Sears Kenmore 6 August 26th, 2006 08:51 AM
Kenmore Elite Dual Fuel Oven Repeat Problems Model C970-445441 mudcat Sears Kenmore 3 January 11th, 2006 01:20 PM
Kenmore slide in, dual fuel problem lakeleader Sears Kenmore 4 November 29th, 2005 10:03 PM
kenmore elite dual fuel range oven doesn't work dawn Sears Kenmore 1 October 2nd, 2005 09:25 PM
