Old November 22nd, 2006, 01:18 PM
usdoc is on a distinguished road
Question Maytag MSD2432GRW refrigerator not defrosting
I have a Maytag MSD2432GRW side by side, about 3 years old that has stopped defrosting. It does not have the ADC board like the diagram says, but has the mechanical timer. When I turn the screw on the timer, the fridge stops running, but no heat or elements are activated in the coil section. I can hear the small timer motor running.
Where do the wires from the mechanical timer run so that I can check what component is bad? Heating element, thermostat?
USDOC
Old November 22nd, 2006, 03:19 PM
Showed a mechanical timer on the parts breakdown.
No power from the timer, open defrost thermostat, open heater would be suspect.
Heater and stat in the freezer.
Defrost timer
Defrost heater and thermostat kit
http://www.applianceaid.com/defrost_cycle.html
Helps.
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old November 25th, 2006, 10:02 PM
Jeff,
Thanks for the excellent reply. I just need to eat a little more of our Thanksgiving food and then do some metering....and order the part!
Will let you know!
As a 35 year field service repairman...this site is wonderful for us!!
Mike
(USDOC)
Old December 1st, 2006, 09:36 AM
Default Bad Thermostat
Jeff,I replaced the heater and thermostat assy. yesterday, and tested after letting it cool down. It worked!The heater coil had 26 ohms of resistance, so I guess the thermoostat is no good. As you know they are in series, and I had to remove the insulation to meter individually.Great shipping by your company!Thanks for the help!Mike
Maytag Neptune 8700 repair issues & Maytag Rant. jazzman_q Maytag Brands Forum 14 May 19th, 2009 11:40 AM
neptune mah3000aww rtwerp Maytag/Magic Chef/Admiral/Jenn-Air 10 July 21st, 2007 09:19 AM
Maytag Neptune - No spin cycle fox_1028 Maytag Brands Forum 1 May 24th, 2006 11:15 AM
Maytag- IS YOUR MAYTAG GENUINE? Rick Hansen RPh General Appliance Chat 1 September 14th, 2005 09:06 AM
Maytag Wide By Side - Compressor dies after 11 months pete_nc Maytag/Magic Chef/Admiral/Jenn-Air 4 August 16th, 2005 10:24 AM
