Results 1 to 8 of 8
Thread: maytag dryer heats but motor doesn't turn
    fred9 is offline Member
    Jun 2005
    Post imported post
    When timer is started the machine heats but motor only humms. (maybe the heat element is humming?) I replaced the motor and no change. I watched the motor shaft from the back when the machine was started and shaft didn't turn.
    The door switch seems to work - the low humming stops when the door is opened.
    Any other items I should check? Thanks, Steve
    Oct 2004
    Post imported post
    Model#?
    http://www.applianceaid.com/model.htmlSome model# helps.
    **When timer is started the machine heats but motor only humms. (maybe the heat element is humming?)**
    Make sure the heating element is not shorted to ground. http://www.applianceaid.com/grounded.htmlSome tips on that.
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Post imported post
    If you can post the model# that would help us as maytag does have different type models.
    Could be a timer issue ora start relay problem.
    Motor turns ok by hand when its installed in the dryer?
    Jun 2005
    Post imported post
    Model # LDE9314ace
    Yes, motor turns by hand when installed.
    Where is start relay? THANKS, Steve
    Oct 2004
    Post imported post
    **Where is start relay?**
    There isn't one.
    **Model # LDE9314ace**
    Access helps to have a peek at that element.....
    http://www.applianceaid.com/may-apart.html#common
    JRAppliance
    Post imported post
    Some Maytags had a start relay in the console, but as Jeff said yours does not.
    You have a start switch on the motor itself, but if you already changed the motor then it should have come with the new motor as a assembly.
    That Link Jeff gave you should help with your dryer problem.
    Jun 2005
    Post imported post
    It was the thermo fuse right in the front. So I wasted over $100 for the motor BUT it did force me to learn how to use a Multimeter - I learned how to check voltage - 220 and 110 and I learned how to check "continuity".
    Thanks for all your help.
    Applianceaid.com was VERY helpful!!
    Steve
    Oct 2004
    Post imported post
    Thankx for the update!!
    JRAppliance
  1. Maytag Electric Dryer GDE808 - Help!!
    By jbird68 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 18th, 2008, 10:51 PM
  2. Maytag Legacy series dryer walks
    By Jann K in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 3rd, 2007, 07:41 PM
  3. Maytag Dryer Noise and Vibration
    By marilano in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 7th, 2005, 05:48 AM
  4. Maytag Dryer Noise and Vibration
    Last Post: September 5th, 2005, 02:03 PM
  5. Maytag Dependable Care Dryer sometimes heats up????
    By tmt in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 9th, 2005, 11:08 AM
