Old December 13th, 2006, 11:05 AM
rage is on a distinguished road
Default maytag (gas) dryer not hot enough
I have an 11 yer old Maytag gas dryer (model 180G???). N E way, after years of great service, it has not been drying as well and I've noticed that my cloths are not as 'hot/warm' as they are removed from the dryer.
I have done a THOUROGH cleaning of the machine! Including vents and gas/flame fixture. I've noticed that the flame does NOT turn off throughout an entire drying cycle. According to what I've read, isn't the thermostats supposed to cycle the heat to maintain a constant temp. (140F?) ??? I tried to 'adjust' the flame on the unit to supply more heat, but nothing seems to actually increase the flame strength/intensity (turned square nut at back of gas inlet). My thought was more flame, higher heat.?
Any suggestions?
Old December 13th, 2006, 01:05 PM
It sounds like your gas valve assembly in your dryer is starting to wear out.
I can't find any info with that model you posted.
Here is a link to help you locate your model#:
http://www.applianceblog.com/mainforums/showthread.php?t=1023
Old December 13th, 2006, 01:13 PM
I have the model# at home and will update shortly... Am I correct to assume that he gas/flame should cycle on and off during a cycle, thus maintaining a near constant temp? The fact that it is on ALL the time tells me it's never getting hot enough.
Old December 13th, 2006, 01:29 PM
Yes, the gas flame should cycle on and off throughout the entire drying cycle, maintaining an average heat temp. of 140-160.
Old December 13th, 2006, 06:01 PM
Jake, the model number of the dryer is: LDG8410AAE. ANy info on how to 'turn up the flame' would be appreciated.
Kurt
Old December 14th, 2006, 01:00 AM
Your on natural gas I assume?
No, there is not a way to turn up the flame, you will need a new gas valve.
Here is a new gas valve for your model:
Gas valve assembly
Old December 14th, 2006, 04:05 PM
alanlay is on a distinguished road
Hi, I've got the same issue with a Speed Queen Dryer, model AGM479W2.
The ignitor initally starts the flame, but on the 3 or 4 time it re-ignites, the blower doesn't catch. Does this sound like a similar fix?
Al
Old December 14th, 2006, 09:10 PM
Al
No, this problem sounds different.
You mean it lites the flame fine on the first time, good flame? But after it cycles 3 or 4 times, theres no flame anymore?
Old December 15th, 2006, 07:37 AM
Yes, it lites fine and heats up the dryer/clothes in side, and does this for the first two or three cycles of the ignitor glowing/igniting the flame. But on like the 4th time the ignitor glows, it does not ignite the flame and then the ignitor fades. After a few minutes, the ignitor glows again and it's hit or miss...sometimes it lights the flame, sometimes not.
Old December 15th, 2006, 11:51 AM
Ok Alan, then in your case a new set of gas coils should fix your dryer.
Here is the gas coils for your dryer you can order:
Gas valve coil kit
Kenmore 70 series gas Dryer not heating right pflowers Sears Kenmore 1 February 12th, 2007 09:14 PM
How to replace to drum roller on maytag gas dryer? rlsmith Maytag/Magic Chef/Admiral/Jenn-Air 5 January 6th, 2007 04:29 PM
Maytag Gas Dryer MDG5500AWW Long drying times alans1 Maytag/Magic Chef/Admiral/Jenn-Air 3 November 13th, 2006 01:44 PM
Maytag Gas Dryer mod#LDG8404AAL Dryer lights, but after about 20-30 seconds goes out, bulkhead Maytag/Magic Chef/Admiral/Jenn-Air 1 September 16th, 2006 07:53 AM
Maytag dryer noisy and hot KenR Maytag/Magic Chef/Admiral/Jenn-Air 1 August 18th, 2005 06:09 AM
