Old December 16th, 2006, 05:33 PM
mikepecka is on a distinguished road
Default warm compressor
I have the maytag msd2756geb and have read the other blogs on no cooling. I did find that the relay overload switch does in fact rattle when removed but the other question i have is wether or not the compressor should feel warm. It has been off for awhile now and even earlier it was very warm but not hot. I do not have ability to check to see if continuity is ok for compressor. When the clicking noise happens it does not appear to be making the compressor run.
Old December 17th, 2006, 12:25 AM
The compressor can still be warm just by your overload/relay trying to start your compressor.
If your not able to check for continuity on that overload/relay or compressor, I would take that overload/relay down to your local appliance parts store on Monday and they can test it for you. If its good, then you know for sure its your compressor.
All compressors come with a 5 yr. parts & labor warranty.
Old December 19th, 2006, 05:12 AM
Will let you know how it plays out thursday.. the part should be here then ...but the place is not sure its the right one.( good grief)
Old December 19th, 2006, 08:23 PM
What place is not sure if its not the correct part?
Old December 21st, 2006, 06:55 PM
my only local parts house. they had to order the part online and it was similar but not the same thing.( they are claiming that maytag is now owned by whirlpool ) it hooked up easily and after what appeared to be an intial "no start" startup...it clicked and the compressor started. Its now cold enough for the auto ice machine to be making ice and the food compartment is getting colder. Looks like you fixed it for me. If you dont hear from me again it means the thing is working.... Thanks again ...ty ty ty ty.... mike
Old December 22nd, 2006, 03:24 AM
Ok, Sounds good Mike, glad its working good now, hopefully that will take care of it for good.
Kenmore 253 compressor failing spommere Sears Kenmore 1 March 25th, 2007 12:39 AM
general compressor info polestar Whirlpool 15 January 8th, 2007 09:59 AM
KitchenAid compressor warm when not running deeppaul KitchenAid 1 August 24th, 2006 03:25 PM
Compressor trouble (I think) badonkadonk Whirlpool 1 January 24th, 2006 12:04 PM
Kenmore SxS Fridge - Bad relay or compressor? jbaker7 Sears Kenmore 7 July 6th, 2005 05:02 PM
