Maytag MTF2456AEW (top freezer type) stopped cooling well a couple of days ago. Unit is about 7 years old. Condenser coils were dirty (this seems to happen about every two years)and I cleaned and verified compressor was running ok. Waited a day but unit was still not cooling well even on highest setting. Looking at this site it suggested that it might be icing up. Evaporator coil was a solid block of ice. Defrosted it with a hair dryer and put it back in service. Figure I have bought a couple of days. Checked the defrost heater element and it measured out at 31 ohms.... sounds like this is typical and means it's probably ok. It sounds like unless I start hearing the defrost heater come on in the next 24 hours (and it's always been loud when it works) then according to this website it probably makes sense to just go ahead and replace the heater thermostat and timer. Sounds like if it is not bad it has a limited service life....... Anyone know where the defrost timer is located on this model? Dave |
Hi dave99,
You'll find the defrost timer located in the center of the plastic control housing mounted on the top of the refrigerator section. Here is the part #68233-3. Rick
Yes, Rick is correct.
Here is the parts diagram for your model MTF2456AEW, you can order the defrost timer diagram#2 part location#15. Defrost heater diagram#3 part location#9. Jake
Rick and Jake,
Thanks much for the help. Greatly appreciated. Dave |
Glad to help Dave.
| Hotpoint Fridge Defrost Timer Location? | tony fanucchi | GE/Hotpoint | 3 | June 19th, 2007 11:03 PM |
| Kenmore Elite 106.55603400 freezer OK, refrig warm | Ashes | Sears Kenmore | 11 | June 19th, 2007 09:52 PM |
| Defrost Timer Location | w6dhr | GE/Hotpoint | 1 | June 8th, 2007 12:22 PM |
| Location of Adaptive Defrost Unit in Amana Bottom Freezer | aclem36 | Amana | 3 | February 24th, 2007 04:15 AM |
| Superba Icing Up In freezer defrost or timer? | lnsmktg | KitchenAid | 1 | August 2nd, 2006 08:46 AM |
