Sounds like your power module assembly will need to be replaced.
Here is your wash motor power module assembly:
Wash motor assembly with seal
You need the original impeller, not the metal one:
Wash impeller
You have a 5 yr. part warranty on this:
http://www.maytag.com/cust_serv/pdf_...01_a_mdb-5.pdf
After the second year from the date of original retail purchase,
through the fifth year, all of the following components which fail in
normal home use will be repaired or replaced free of charge for
the part itself, with the owner paying all other costs, including
labor, mileage, transportation, trip and diagnostic charges, if
required. These components include:
All parts of the Jetclean II® wash system for all models, including
the complete power module assembly, soil sensor, spray arms,
wash manifold and motor.
Contact Maytag to have a tech. come out to order the parts you need.
LinkBack URL
About LinkBacks
Wash impeller
