Old January 8th, 2007, 08:12 AM
KAM KAM is offline
KAM is on a distinguished road
Default Maytag not cooling
My Maytag sxs fridge stopped cooling though it seems to run constantly. The compressor, fan and coils seem to be fine. It isn't defrosting properly (model MSD2656GE). We uncovered the coiled totally filling the back of the freezer. We tried to follow your fridge not cooling help page...
The heater has 2 wires; one has continuity and the other has resistance. We could not find the timer at all. We found the theromstat seems to be open?
Any specific ideas where the timer is or what we can try?
Thanks so much!
Old January 8th, 2007, 10:31 AM
Your defrost control is located in the right rear of your console in the refrigerator section, its the exact same as in this thread:
http://www.applianceblog.com/mainforums/showthread.php?t=223
Now ohm the heater wire and post what it says.
Your defrost thermostat should be attached to the evaporator coil and frosty to get an accurate reading for a continuity check with your ohm meter.
So if you read through this thread carefully and throughly you will be able to fix this yourself with no problems, if you think its to much and to in depth, be all means call an appliance repair company in your area to do this for you.
Maytag Refrigerator #MBB2256GEW cooling issue SueE Maytag/Magic Chef/Admiral/Jenn-Air 5 January 6th, 2007 03:04 AM
Maytag ptb1954grw no freezer/no fridge cooling Gugerluards Maytag/Magic Chef/Admiral/Jenn-Air 3 December 29th, 2006 05:54 AM
Maytag PTB195LGRW not cooling rocksguy Maytag/Magic Chef/Admiral/Jenn-Air 2 August 9th, 2006 11:36 AM
Maytag MSD2456GE Quit Cooling then... Alf50990 Maytag/Magic Chef/Admiral/Jenn-Air 11 March 27th, 2006 12:39 AM
