Old January 9th, 2007, 09:59 PM
mitchellra is on a distinguished road
Default Maytag PTB1954GR not cooling
My Maytag PTB1954GR has ceased to cool properly. There is an audible click, and the compressor starts to run, but for only 20-30 seconds, then stops with another audible click. After a couple of minutes, it repeats. In another thread, someone mentioned the run capacitor and overload relay. Could the run capacitor cause this problem, or is it more likely to be the overload relay? Or is it something else entirely? I would really appreciate any help.
Old January 9th, 2007, 10:15 PM
Nope.
That is one possible trouble maker.
Clickiing on and off compressor:
Compressor
Start relay/overload
Low voltage ( extension cord )
None working condensor fan motor
These are likely most to least common.
http://www.applianceaid.com/refrigerator.html#clicking
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old January 10th, 2007, 10:33 AM
Default Thanks!
Thanks for the info. As for the relay/overload switch, I will test it this evening. If it is the relay/overload switch, is there any possibility the constant off/on could have damaged the compressor as well? The refrigerator is only a little over 5 years old. I would hate to spend the money to replace the switch, only to find out the compressor needs replaced as well. Thanks again for your help!
Old January 10th, 2007, 09:27 PM
Yes....but you may not know until you try it out...I'll usually ohm the compressor windings and if they are intact I try another relay and have the amp meter ready to check the compressor current draw it if fires up and runs.
JRAppliance
Maytag Refrigerator #MBB2256GEW cooling issue SueE Maytag/Magic Chef/Admiral/Jenn-Air 5 January 6th, 2007 03:04 AM
Maytag ptb1954grw no freezer/no fridge cooling Gugerluards Maytag/Magic Chef/Admiral/Jenn-Air 3 December 29th, 2006 05:54 AM
Maytag PTB195LGRW not cooling rocksguy Maytag/Magic Chef/Admiral/Jenn-Air 2 August 9th, 2006 11:36 AM
Maytag MSD2456GE Quit Cooling then... Alf50990 Maytag/Magic Chef/Admiral/Jenn-Air 11 March 27th, 2006 12:39 AM
