Old February 7th, 2007, 07:29 PM
wayned is on a distinguished road
Default water/ice dispenser runs
maytag model MSD2754GRW REFRIG at times dispenser will not shut off when releasing glass from under chute.possible switch or other failed part on its way out.any input would be helpful thanks wayne
Old February 8th, 2007, 01:47 AM
Changing your control board and limit switch should fix it.
Here is your dispenser control board, you can order:
Control board
And your Limit Switch:
Switch
Old February 8th, 2007, 07:59 PM
Changing your control board and limit switch should fix it.thanks for the quick reply jake.do you think one could not try the limit switch first?just changing both can be costly for a maybe fix.any one else ever run across this type of problem.thanks in advance wayne
Old February 9th, 2007, 01:38 AM
Yes, you can go with the limit switch first.
AMANA water/Ice Dispenser not working. PANEL? mfjohnston Amana 5 June 14th, 2007 10:06 PM
water/ice dispenser not working maryjamo Amana 1 December 13th, 2006 10:44 PM
no power to water/ice dispenser? n11 Frigidaire/Electrolux 3 November 20th, 2006 09:29 AM
Removing a GE water/ice dispenser Frank E W GE/Hotpoint 5 November 14th, 2006 12:23 AM
frigidaire water/ice dispenser inop exwoodsplitter Frigidaire/Electrolux 1 January 16th, 2006 11:18 AM
