Old February 9th, 2007, 10:06 PM
az1324 is on a distinguished road
Default Jenn-Air Built in Refrigerator Freezer Fan Noise!
I have a Jenn-Air Built in Refrigerator. The freezer fan is making a loud continuous noise whenever it's on. I confirmed it was this fan by running the system tests. Does anyone have an idea what could be wrong with the fan? Also where is it located so that I can take a look at it? Do I need to pull out the whole unit cause if so its a chore.
Old February 9th, 2007, 10:27 PM
Whats the model# of your refrigerator? it should be located inside your refrigerator section on the sides or ceiling.
Old February 10th, 2007, 01:09 AM
Js42sedbda
Old February 10th, 2007, 11:46 AM
#9 here is your freezer fan motor:
http://www3.sears.com/imaging/ImageP...&titleID=00005
Its behind your back freezer panel inside your freezer, if you just take out your food and remove that panel, you should see it.
Here is a new one for your model, in case you need to order it(click photo for pricing/ordering information):
Old February 10th, 2007, 03:48 PM
Thanks for the diagram.
This is what I found:
An iceberg had formed from dripping water and slowly climbed up the wires and into the path of the fan blades.
I used a heat gun to loosen the frozen wires and removed the ice.
Now it looks like this:
and all is well.
Thanks again.
Old February 11th, 2007, 11:21 AM
wow, thats alot of ice, it looks like you have either a water leak in that area, or your defrost drain line is clogged up.
Jenn Air W130W fan question halseyf Maytag Brands Forum 0 February 5th, 2007 09:36 AM
Problem with Jenn air down draft slide in range. jerr462 Maytag/Magic Chef/Admiral/Jenn-Air 6 January 9th, 2007 11:36 PM
GE Arctica fan noise bradvabeach GE/Hotpoint 3 October 7th, 2006 09:29 PM
Jenn Air Downdraft Cooktop Replacement mfrank2109 Antique and Retro Appliance Chat 1 October 5th, 2006 11:39 PM
jenn air fridge blowing warm air ribeye35 Maytag/Magic Chef/Admiral/Jenn-Air 6 December 1st, 2004 02:23 PM
