Old July 11th, 2005, 08:23 PM
BenChang is on a distinguished road
Post imported post
My Maytag dryer (Model # is: Maytag DE608) is a pretty old one. Now it won't turn (acctually it turned a little bit and stopped) and the timer button cannot be pressed down.
I did some test. When I lose the belt, the motor turned and the timer button could be pressed down. Then I took the drum out. I tried turning roller, pulley and motor with hand. One of the back rollers, pulley and motor were hard to turn. I oiled them and put the drum back. Still, whenever I fastened the belt, the motor glided a little bit then stopped.
I am not so sure where the problem is. It seems the motor is OK. Please give me some hints. Any suggestion would be appriciated.
Thank you!
Old July 12th, 2005, 12:35 AM
Post imported post
Here is a good link for your Maytag Dryer, the problem could be the rollers, idler pulley, motor bearing, blower wheel, front glide assembly.
Link>http://www.applianceaid.com/maytag-dryers.html
Old July 12th, 2005, 04:45 AM
Post imported post
**whenever I fastened the belt, the motor glided a little bit then stopped.
I am not so sure where the problem is. It seems the motor is OK.**
Does the motor end look anything like this....
http://www.applianceaid.com/drymotor_bad.html
http://www.applianceaid.com/may_motor_dryer.html
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old July 12th, 2005, 05:27 PM
Post imported post
You are right. The motor looks bad. I am going to replace that.
Thank you
Old July 13th, 2005, 04:32 AM
Post imported post
If you get a chance, let us know how the repair goes.
JRAppliance
Old July 15th, 2005, 07:27 PM
Post imported post
I want to replace the motor.
But on top of the shaft, that little thing (I think it is called pulley), I could not take it off. It was too tight to take the screw off. Beside the shaft turned when I twisted the wrench.
How to take it off?
Old July 15th, 2005, 08:00 PM
Post imported post
**But on top of the shaft, that little thing (I think it is called pulley)**
Motor pulley?
Motor pulley and set screw
If yes....these can be VERY tight and may not come off....I usually bring a new one with me "just in case"....you can try tapping on the set screw with a hammer or try a little heat on the pulley to loosen the set screw up....1/2 of the time they will not come off for me either.
JRAppliance
Amana (Maytag) dryer: 505474P timer assembly (BRAND NEW!!!) pantero21 Buy, Sell or Trade 0 January 24th, 2007 05:18 PM
Maytag Dryer Won't Run When Press Care Button Off kjr232 Maytag/Magic Chef/Admiral/Jenn-Air 1 October 29th, 2006 08:23 PM
Maytag Dryer LDE7304ACE, won't start dorton Maytag/Magic Chef/Admiral/Jenn-Air 1 March 31st, 2006 01:20 AM
Gas dryer timer will NOT stop originalboxcar Whirlpool/KitchenAid 1 January 14th, 2006 08:30 AM
Dryer only runs when start button is held pacaron Frigidaire/Electrolux 1 December 22nd, 2005 11:07 AM
