Old March 16th, 2007, 07:14 AM
zoso0 is on a distinguished road
Default Maytag MTB2156GEW
Hi.
I have a top freezer, what I've noticed is that the fridge only cools to 50F and the freezer 13F. I bought the fridge in august 2003, has anyone had the same problem? Any ideas, should I increase the temperature settings?
Alberto
Old March 16th, 2007, 10:39 AM
Look inside your freezer at your back panel #2 here:
http://www3.sears.com/imaging/ImageP...&titleID=00004
Is that panel frosted-up?
Old March 16th, 2007, 11:35 AM
Hi.
I'll check when I get home, what i did notice was in the fridge on the ceiling where the air blows in from the freezer some ice accumulated. It's like water has dripped in or due to condensation.
For the panel in the freezer do I have to remove the panel?
alberto
Old March 17th, 2007, 07:13 AM
Hi.
I removed the rear panel in the freezer no ice build up. I've cleaned the dust in the rear of the fridge.
I'll allow the fridge to defrost the ice that remains in the fridge in the ceiling and then start it up later, any ideas what can be the problem.
alberto
Old March 17th, 2007, 11:37 AM
Whats the temperatures are in the freezer and refrigerator sections after you de-ice that air duct and let it run for awhile? give it 4-6 hours.
Old March 17th, 2007, 11:55 AM
Hi.
I haven't pluged the fridge back in, should I? I was going to let it sit for at least 12 hours unplugged, unless i heard anything I'll only plug it in tomorrow morning. Then I'll measure the temperatures in both the fridge and freezer sections.
alberto
Old March 18th, 2007, 10:34 AM
Ok, thats fine to let it sit longer till you plug it back in.
Old March 18th, 2007, 11:02 AM
I plugged it in and set the control settings to 6 respectively. The freezer is at about 6F and fridge at 56F, both freezer and fridge are completely empty. (it's been 4hrs now) The fan in the freezer hasn't kicked in yet, is that normal?
Any other ideas?
Alberto
Old March 19th, 2007, 09:45 AM
Hi.
After oneday the freezer is at -1-0F but the fridge is still at 50F. I haven't heard the Fan in the freezer kick-in since I plugged in the fridge.
Old March 20th, 2007, 12:05 PM
Its likely your fan motor is bad, but you would need to test the voltage to it.
Maytag Neptune 8700 repair issues & Maytag Rant. jazzman_q Maytag Brands Forum 14 May 19th, 2009 11:40 AM
neptune mah3000aww rtwerp Maytag/Magic Chef/Admiral/Jenn-Air 10 July 21st, 2007 09:19 AM
Maytag Neptune - No spin cycle fox_1028 Maytag Brands Forum 1 May 24th, 2006 11:15 AM
Maytag- IS YOUR MAYTAG GENUINE? Rick Hansen RPh General Appliance Chat 1 September 14th, 2005 09:06 AM
Maytag Wide By Side - Compressor dies after 11 months pete_nc Maytag/Magic Chef/Admiral/Jenn-Air 4 August 16th, 2005 10:24 AM
