Old July 14th, 2005, 01:15 PM
jagdishsg is on a distinguished road
Post imported post
The freezer becomes very cold and cooling fins completely ice up, even the vent to fridge side ices & blocks air flow to the fridge side. The Auto defroster was removed and it tested ok. Defroster heat coil resistance from defroster plug read 240K, which seems tobe ok. I am not sure if the thermostat in the heater assembly is ok.
Old July 14th, 2005, 11:11 PM
Post imported post
Just use your Ohm Meter to check the continuity of the heater and defrost thermostat(making sure the defrost thermostat is very cold with frost on it when you test it.) both should have continuity.
Old July 15th, 2005, 12:44 PM
Post imported post
Hi Jake,
Heater continuity cheked normal, and I have replaced the the thermostat. Frezzer seems to cool ok(-18 Deg C or +0.0 Deg F), but fridge still seems to be warm running at +10 Deg C or 45 Deg F. I think the fridgetemp shouldbe around34 Deg F. Freezer fan seems to work ok, any suggetions!!
Jagdish
Old July 16th, 2005, 12:26 AM
Post imported post
Normal refrigerator temperature is 37-42, i would open the air duct to the refrigerator section more, which means turning it less cool in the freezer, that will open the refrigerator air duct more.
Also the door gaskets for leaks or rips in the gaskets, make sure your condenser is clean too.
Maytag Model MSD2657HEQ fridge side warm robivi3 Maytag/Magic Chef/Admiral/Jenn-Air 5 June 9th, 2007 03:29 PM
Maytag Side by side leaking jrc0109 Maytag/Magic Chef/Admiral/Jenn-Air 3 October 17th, 2005 12:11 AM
Maytag MSD2454GR Side by Side Refrigerator Kent Maytag/Magic Chef/Admiral/Jenn-Air 1 September 17th, 2005 06:22 AM
Maytag Wide By Side - Compressor dies after 11 months pete_nc Maytag/Magic Chef/Admiral/Jenn-Air 4 August 16th, 2005 10:24 AM
Maytag Side by Side Model MSD2456GE Tokyo-Rob Maytag/Magic Chef/Admiral/Jenn-Air 1 May 29th, 2005 06:43 AM
