Old May 12th, 2007, 11:14 PM
billdoublewide is on a distinguished road
Default diagram for Maytag top-freezer unit?
I suspect that I have a plugged defrost drain system (water leaking inside fridge). Maytag top-freezer model MTB2656AEW.
I'd like to see a diagram if there is one out there before I start tearing into it.
Thanks in advance.
Old May 14th, 2007, 11:00 AM
Here is the parts diagram for your model:
MTB2656AEW
Diagram#2 part location#11 is were the defrost water drains down to, then out through the back wall and down to your drain pan.
Old May 14th, 2007, 01:55 PM
Thanks, Jake.
I ran a roto-rooter (weedeater line, works great) up from the tube that drips into the drain pan at the bottom all the way up near the console on the ceiling of the fridge ("damper kit"?). I did not come across any obvious blockage.
Since the water is collecting in the fridge and is sometimes visibly dripping from this console and is not collecting in the freezer part. I assume that there is something amiss within this assembly. The fridge appears otherwise to be working (cools well, no frost build-up). It seems that there must be some sort of blockage right there.
Does this sound reasonable to you? Thanks.
Old May 15th, 2007, 10:39 AM
Yes, try to get some kind of pressurized air so you can blow down through the tubing to the drain pan. Shoot water down that tube with a turkey baster of something along that line.
Location of Adaptive Defrost Unit in Amana Bottom Freezer aclem36 Amana 3 February 24th, 2007 06:15 AM
Kenmore Top Freezer Defrosting problems wenningj Sears Kenmore 1 February 11th, 2007 11:59 AM
Top mount freezer not cooling (Unit in garage)spare freezerburn Frigidaire/Electrolux 4 February 4th, 2007 12:08 PM
Location of Defrost timer for Maytag 2456AEW (Top freezer)? dave99 Maytag/Magic Chef/Admiral/Jenn-Air 4 December 26th, 2006 11:18 PM
Kenmore 587.15152400 dishwasher top spray arm not working eprosenx Sears Kenmore 3 December 14th, 2006 09:23 PM
