I've had this side-by-side fridge/freezer since 1996. Last year the maytag repair guy came over and replaced the defrost coil because it had a couple holes in it that prevented it from defrosting the cooling coil and prevented the unit from cooling. He mentioned that this very rarely happens.
Now its doing it again. I removed the panel in the back of the freezer compartment and thawed out the cooling coil and its working now until the coil freezes again. Any suggestions? We've also had a problem with moisture and frost on the fridge side but just learned to live with it. Thermostat settings are always fridge 5-7 (depending on amount of contents) freezer 5. Thanks for the help! |
Ok, you would need to ohm your defrost heater/defrost thermostat for continuity, while its still frosty. Here is a help link for doing this: http://www.applianceaid.com/frig_notcold.html#ff If both check normal, then your problem lies in your adaptive defrost board, and we have a thread that explains it here: http://www.applianceblog.com/mainforums/showthread.php?t=223 Jake
Thank you very helpful. Can you link me a diagram that show location and removal (if necessary) of the defrost board? |
Jake,Found the link thanks! |
Glad to help.
| Maytag MBB2254GEW frost problem | marcusH | Maytag/Magic Chef/Admiral/Jenn-Air | 5 | March 2nd, 2007 07:04 PM |
| Location of Defrost timer for Maytag 2456AEW (Top freezer)? | dave99 | Maytag/Magic Chef/Admiral/Jenn-Air | 4 | December 26th, 2006 11:18 PM |
| Maytag 1502ARW problem | Katiemay | Maytag/Magic Chef/Admiral/Jenn-Air | 11 | August 30th, 2006 12:49 PM |
| Maytag Refuses To Solve Problem | Mike B | Maytag Brands Forum | 2 | July 14th, 2006 12:01 AM |
| Maytag washer hopping problem | Ken Brekke | Maytag/Magic Chef/Admiral/Jenn-Air | 5 | March 7th, 2006 12:53 AM |
