Hello, We have a Maytag Neptune model # MAH5500BWQ that won't let cold water in. If it's set on warm it only fills with hot water and if it's set on cold only it just doesn't fill at all. I'm thinking maybe a solenoid valve is bad on the incoming cold water? I do have cold supply coming in as I'm working around it right now by swithing hot and cold hoses and setting it to hot. Jake has helped me on our double oven and figured I'd ask here before I even checked it out. Thanks for any help pointing me in the right direction.
Thanks, Mark Thompson |
Hi Mark,
You're on the right track, probably need to replace the water valve. There are three water valves for that model make sure you know what series you have if you have to replace it. Rick
Thanks Rick,
I'm ordering the water valve now. The first 2 digits of the serial# is the series#, right? After looking on several of the parts websites it looks like there is a series 10, 83, and 87. My serial # starts with 85. One of the sites said serial #s 83 and above use series 83 (part#22003834). Does that sound right? Again, thanks for your help. Mark |
Yes, thats correct. Series 87 would be the serial#'s starting with 87 and up. So series 83 is what you need.
Here is the cheapest price I found on your water valve: Part#22003834 Water inlet valve w/thermistorJake
| Kenmore 80 Series Washer - cold water vibrates | rickwh | Sears Kenmore | 1 | August 7th, 2006 09:36 AM |
| kenmore washer won't fill with water | juanchez | Sears Kenmore | 5 | May 15th, 2006 04:06 PM |
| Maytag Water fill Neptune front load | copierdoc | Maytag/Magic Chef/Admiral/Jenn-Air | 7 | October 13th, 2005 12:49 PM |
| Kenmore 80 Series No Cold Water During Rinse Cycle | poweruser | Sears Kenmore | 3 | September 1st, 2005 06:24 PM |
