Results 1 to 2 of 2
Thread: MAH5500A control board help
    bosshogg is offline Member
    Jun 2007
    MD
    Default MAH5500A control board help
    Background:
    I have a Maytag MAH5500A washer. The machine won't agitate in the wash cycles (fills, then turns off) and won't spin in the spin cycle (drains, door locked lamp lights, then turns off). I thought the problem was with the motor, so I called a Maytag repair guy since the motor is still under warranty. The guy wanted $475 to replace the main control board and the wax motor. I decided I could order the parts myself and save over $200. I then discovered that my control board had the burnt (only slightly) R11 resistor. So I replaced R11 and Q6, along with the wax motor. I still have the same problem. Tonight I'll try the drive system check and look for 24V at the spin lock enable wire on the control board.
    My question:
    I noticed a header on the control board labeled P6, the header has 3 pairs of pins labeled "diagnostics", "spin speed", and "slow fill". Does anyone know if these are jumper points or probe points? I was wondering if I put a probe across the diagnostics pins that I'd get some sort of flashing sequence, like the engine lamp on a car. If anyone has any info on the P6 header pins, that would be appreciated...
    Thanks.
    Jun 2007
    MD
    Default more info...
    I found the following image on the P6 connection:
    And an explanation on the SLOWFILL jumper...
    Pins 1-4 are labeled DIAGNOSTICS on my MAH5500AWW control board.
  1. GE JVM2070SK - 2nd control board dead
    By dfenwick in forum GE/Hotpoint
    Last Post: June 4th, 2011, 06:23 AM
  2. Neptune motor control board burn out
    By handyjoe in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 31st, 2008, 05:26 PM
  3. motor, motor control or control board???
    By bosshogg in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 21st, 2007, 11:02 AM
  4. Maytag Neptune Control Board Issue
    By tim205 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 17th, 2007, 10:46 PM
  5. how to change a control panel AND a control board
    By corkyone in forum Sears Kenmore
    Last Post: April 29th, 2006, 12:17 AM
