Results 1 to 3 of 3
Thread: LG Gas Range; uneven super burner flame
    Dvinechild is offline Member
    Feb 2011
    Marion, WI
    Default LG Gas Range; uneven super burner flame
    Model Number: 30357
    Brand: LG
    Hello,
    Recently noticed uneven flame from front right burner (super burner). There is considerably more flame between 6&9, continuing to 12 o'clock. I have cleaned everything cosmetically possible and could get at with scrubby/toothbrush with no success. Assured that everything was even (screws, etc) and nothing alters the flame. There are no other issues the the remaining 4 burners.
    I have noticed that the range may need to be slightly raised in the front to make front/back a bit more level, but this has not effected the range/flames with prior use and other oven/broiler adjustments made.
    If you could assist, it would be appreciated.
    Run range from LP, installed LP converter kit.
    I don't have any experience on LG products.
    Hopefully another tech. that does, can assist you.
    wildimaginations's Avatar
    wildimaginations is offline Appliance Tech
    Jun 2011
    Danville, California
    Quote Originally Posted by Dvinechild View Post
    Hello,
    You may have a warped burner head causing the flame to burn unevenly. It cannot be repaired, you will need to replace the burner head and base together.
    Good luck
  1. Gas vs. Electric Range? Here is one more view...
    By bobl in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 14th, 2012, 08:22 PM
  2. Maytag Gas range burner not lighting- I think electrode needs cleaning but how?
    By dieselgg in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 18th, 2010, 04:23 PM
  3. Gas range Burner Igniter does not Stop Sparking
    By rschwarz in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 6th, 2009, 09:34 AM
  4. Flame cuts out ont Gas Kenmore 110.78942892
    By SD Paul in forum Sears Kenmore
    Last Post: February 15th, 2009, 12:45 PM
  5. Maytag Slide In Gas Range (MGS5770ADC) Possible Burner Retro-fit??
    By phull67 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 7th, 2007, 11:36 PM
