November 7th, 2011, 06:57 AM
Montgomery Ward Gas Range: Ignitor Or Valve?
Montgomery Ward
Hi Guys,
The ignitor glows and gets hot but the oven never lights. The valve is an Eaton NC-4153-5.
I'd like to be sure it's the valve before trying to locate one.
thx
bob
November 7th, 2011, 10:11 AM
Hi Bob,
You will need a new oven igniter, I need the model# of your range, click here to locate it.
November 7th, 2011, 12:47 PM
Originally Posted by
Hi Bob,
here to locate it.
Thanks, Jake
I'll have to locate that. How do you tell it's the igniter and not the valve?
bob
November 7th, 2011, 02:44 PM
Jeff explains it here:
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
Courtsey of http://www.applianceaid.com/gas.html#glow
November 7th, 2011, 03:50 PM
Thanks, Jake
That's some great info. I do have an amprobe, etc. I work on pool/spa equip.
If I could generate the proper voltage across the valve terminal, could I test the valve since I already have it out of the oven?
thx
bob
November 7th, 2011, 04:49 PM
BTW, How the heck do you get the broiler door removed? What a pain working around that
bob
November 8th, 2011, 10:52 AM
No Bob, the ignitor has to be connected into the oven to test amps.
I need your model# to assist you with the broiler door.
November 8th, 2011, 02:42 PM
Jake, I'm helping a friend and will have to check. All I found was a long number on the schematic when I looked.
thx
bob
November 8th, 2011, 08:51 PM
November 27th, 2011, 11:11 PM
Hi Jake,
My friend sent me these numbers:
191T122F340
2445-80
PN560T590P05
Do any of those make sense?
By CDoble in forum Refrigerators & Freezers
Last Post: August 6th, 2009, 10:10 AM
By kvanderstel in forum Ranges/Ovens
Last Post: March 4th, 2008, 03:46 PM
By applianceblogkw in forum Dishwashers
Last Post: July 8th, 2007, 04:44 PM
By radiant_truth in forum Frigidaire/Tappan/Electrolux
Last Post: May 30th, 2005, 11:56 PM
