Results 1 to 2 of 2
Thread: Dacor burner valve not triggering microswitch
    marketwolf is offline Member
    Jul 2012
    Jackson, Wyoming
    Default Dacor burner valve not triggering microswitch
    Model Number: RSD30R/LP
    Brand: -major brand-
    Age: More than 10 years
    After removing range top and compartment top, I found that the small black plastic cogged collar on the metal valve knob stem was slipping easily as I turned on the gas and thus not triggering the microswitch (which works fine otherwise). It also appears that the very small metal c-clip that usually grabs the grove in the metal stem and holds the collar inward is missing.
    Is there a clever way of fixing this without replacing the expensive burner valve assembly?? Or, if I bought a new burner valve assembly, could I transfer the c-clip or the c-clip/collar from the new to the old without changing out the whole control valve assembly??
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    I've been looking for information on that range but no luck. If you want to take some pictures of what you're referring to and post them here, I'll be happy to take a look at them.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  1. Door Open Microswitch Foo'd
    By Stephen Price in forum KitchenAid
    Last Post: February 17th, 2011, 03:27 PM
  2. Ice/Water Dispenser Microswitch Sticking
    By Spin2Win in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 28th, 2010, 12:26 PM
  3. Dacor cooktop: one burner reluctant to ignite
    By Netpog in forum Ranges/Ovens
    Last Post: April 13th, 2010, 06:30 PM
  4. Dacor C300 EM6 modules.
    By davidlduval in forum Buy, Sell or Trade
    Last Post: February 5th, 2008, 08:19 AM
  5. new Jenn air burner valve, Leaking?
    By EricT in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 9th, 2006, 12:18 AM
