Icemaker assembly, For In-Door Ice models.
Manufacturer's Part#: 2198597
Complete icemaker assembly (8 cube) - This icemaker is for 25-27 cubic feet models that have vertical auger dispenser installed in the freezer door. 8 cube icemaker.
5 cube ice maker:
Manufacturer part number W10190961 is RepairClinic item number 1468991
W10190961
Here's the instructions TO change the ice maker assembly:
1. Remove the bucket from the door to get some room.
2. Put a piece of tape on the sensor flapper to hold it down so you won't damage it while removing the ice maker.
3. Remove the ice maker service cover door by spreading the two hinge fingers apart away from the center and the door should lift out of the slot.
4. Remove the screw in the right rear bottom side of the ice maker.
5. After removing the screw that cover should lift up from the rear and just work it out from the rear and you see the electrical harness.
6. On the left track the should be a tab toward the bottom which you need to push up.
7. Push up tab and start working the ice maker towards you pulling it out of the track.
8. Careful with the electrical harness in the back as you're pulling out.
9. Disconnect the electrical plug by lifting the clip on the plug.
10. Remove the side cover on the side module by pulling off.
11. Remove the bottom shield by removing the 3 screws on the bottom.
12. To install reverse the order as it came out.
Courtesy of speedemon
To change just the Ice Maker Module:
12. Remove the 3 screws on the ice maker module, then pull the module off.
13. Remove the 2 screws that hold the head assembly onto the ice maker mold tray, then pull the ice maker head off the ice maker mold tray, then you can remove the ejector arm and stripper.
14. To install reverse the order as it came out.
