Page 1 of 37 12311 ... LastLast
Results 1 to 10 of 370
Thread: Kenmore & Whirlpool Ice Maker LED Blinking Codes
    Default Kenmore & Whirlpool Ice Maker LED Blinking Codes
    Model Number: 106 Whirlpool
    Brand: -major brand-
    Ok, I have my chart here for the Ice Maker Blinking Codes:
    Step#1: Open the freezer and view the status led
    (STATUS LED)
    2 BLINKS FOLLOWED BY 1 SEC. DELAY(REPEATED)
    POSSIBLE CAUSES: The flapper door on the emitter is blocking the beam or the optics are faultly.
    Step#2: Press the emitter flapper to unblock the optics beam
    (STATUS LED)
    POSSIBLE CAUSES: The optics are faulty. Replace the emitter and receiver boards.
    If the LED is on steady: The optics are working properly.
    Here are the boards you can order, they come together in 1 kit with instructions:
    Manufacturer part number 4389102 is RepairClinic item number 921526
    4389102
    a10acboy is offline Member
    Feb 2006
    Texas
    Thank you for your help. I'll let you know how it turns out.
    Nelson
    Sounds good Nelson.
    hcpitt931 is offline Member
    Feb 2006
    Oklahoma City
    Exclamation When Running this LED Test
    Dont worry about the door closed switch at the top of the fridge. I kept on wondering if it was supposed to be taped down to make the thing think that the door was closed etc....(like in normal operation) The test described above is run with the door open(thus the fridge light is on) If you tape the switch at the top of the door shut(light is out) then it just causes the LED to do remain out and makes you think the system is broke(at least i did until i looked at the wiring diagram and noticed the reprecussions) RUN THE LED TEST WITH THE FREEZER DOOR OPEN
    clint
    noleatl is offline Member
    Mar 2006
    Marietta
    What if the led light is not lit at all?
    Feb 2006
    Texas
    Default Success!!!
    I order the parts, they arrived in 2 days. It took about 5 minutes to install, and it works like a charm. The parts supplier was fast and much cheaper than Sears.
    Thanks for all of your help!
    Nelson
    "Gravity..... It's not just a good idea, it's the law!"
    Quote Originally Posted by noleatl
    Then you would need the new P.C. Board assembly listed above.
    Quote Originally Posted by a10acboy
    Nelson
    Good job Nelson, glad you got it working again!
    Thanks for the update.
    Mar 2006
    Marietta
    Thanks, I have not yet taken out the icemaker so forgive my ignorance. Where is the PCB located? Is it in the icemaker? Elswhere?
    Quote Originally Posted by Jake
    Feb 2006
    Texas
    Default PCB location
    As you open the door on the side-by-side, the PCB receiver is on the side wall with the ice maker lever (left hand on my fridge), the PCB transmitter is on the side that also contains the on/off switch (right hand on my fridge). 3 screws holds the cover on.
  1. Whirlpool Cabrio UL & F51 Error Codes
    By VJH1968 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 13th, 2013, 11:31 AM
  2. Replies: 4
    Last Post: September 18th, 2012, 09:25 AM
  3. kenmore Ice maker not working--red light blinking
    By sard in forum Sears Kenmore
    Last Post: October 22nd, 2011, 12:29 PM
  4. kENMORE hE4T Codes / WHirlpool Duet Error Codes Link & f02
    By Tryspammingme in forum Sears Kenmore
    Last Post: April 30th, 2006, 10:00 AM
  5. Whirlpool Double Oven - E6 F2 Codes
    By Sarge in forum Whirlpool/Roper
    Last Post: April 16th, 2006, 01:20 AM
