January 11th, 2011, 10:18 AM
[FIXED] Haier wine fridge, not cooling
Hello, I just bought used wine fridge and it does not cool. The guy I bought it from said it needed re-charged, but he didn't tell me how he knew this.
First, everything looks nice and clean , no leaks, rust... It seems the compressor runs, but does not cool. I can hear the coolant boiling (gurgling) inside the fridge. It gets cool to the touch, but not cold. After a while the compressor will get hot, so I unplug it.
It has a LG compressor RSIR type (NSA36LACG) R134a coolant, P6R8MC PTC starter
I checked the Ohm's on the three pins R-C-S
RS- 15Ω
SC- 9Ω
RC- 7Ω
there was no reading (OL)from the pins to the case(ground)
I ran 110v to the 'C' and 'R' and a momentary switch to to the 'S' to test the compressor. Since I have never heard this compressor, I'm not 100% sure it is working. But it seems to work, it's much quieter than older compressors I have heard - it vibrates and hums, just can't be sure it's pumping. But I do hear coolant inside the fridge so I think it's moving coolant.
My conclusion is it is ether the compressor which is not working right or it is low on coolant. This is a closed system, no valves to add or test coolant. I am leaning toward the compressor being bad because I can still hear the coolant, and I think if there were a leak, all of it would leak out.
The compressor is under warranty but not the labor, labor was estimated at over $200, new it was only $150. Haier won't send me a compressor only an authorized dealer and after they have determined it to be bad.
Any ideas as to how I can make sure the compressor is working correctly, or a way to check the coolant?
January 11th, 2011, 12:29 PM
Yes, sounds like a bad compressor internally not pumping the froen around the sealed system like it should.
Unfortunately, consumer's can't change their own compressor, unless you have a refrigerate license and a refrigerant recovery device and a turbo torch, with lots of sandpaper and solder for welding and new R-134a refrigerant.
Thats why its never a good idea to buy a used refrigerator or wine cooler when the guy you buy it from says it needs to be re-charged.
January 11th, 2011, 12:45 PM
Everything is becoming too expensive to fix, it's a shame. I wish Haier made it easier to access the lines to test them.
If I added some R134a to the system, I would know if it were the compressor or a slow leak. The compressor has three lines: high and low pressure and a stub - Is this stub where I should tap into the line and add the R134a? Is this the process line, LG labels this stub as the suction line?
January 11th, 2011, 05:47 PM
Yes, the stub you can tap into or the low side, do you manifold gages to see what the low side pressure is?
The low side should measure between 1-3 for pressure.
January 12th, 2011, 05:24 AM
I had read that the low side should be 103 psi - are the pressures different for the stub and low side? Thanks for all your help - I will get some gauges to use, beg borrow or steal. I understand I will have to braze on a A-1 line tap and I read the system should only take 2oz of R134a - does this sound right to you guys? And then when I'm done, what do I do with the tap, do I braze that shut as well?
I left the fridge plugged in all night, this morning it was down to 60F - this is within the normal operating temp. I turned the controller down to 50F and will see if it keeps working. But the compressor is very hot. Does the compressor run this hot by design? I still feel something is wrong somewhere
January 12th, 2011, 09:53 AM
Where did you read that at? I've been changing compressor's for over 20 years and its always suppose to be between 1-3 for pressure on the low side when its running.
Yes, 2oz. of R134a sounds about right for a wine cooler, normal refrigerators take between 5-6 oz.
If you braze the tap-in then you don't need to remove it, leave it on, you only have to remove the tap-in if you use a non-braze type tap-in.
With the compressor that hot, that tells me its a bad compressor, so I doubt you will do any good by trying to add freon.
January 12th, 2011, 10:14 AM
That could have been a typo '0' and '1' are next to each other on my keyboard. A friend of mine has a manifold and tap I could use...
I think it is the compressor too, I was just wishing for another option. If I could get the compressor I would fix this thing. But Haier won't ship me the compressor even though it's still under warrantee. I have to get an authorized dealer to look at it and they will ship it to them.
Thanks for all the help
January 12th, 2011, 10:49 AM
January 12th, 2011, 05:20 PM
trex66
the '0' and '-' keys are next to each other...
January 12th, 2011, 06:50 PM
I'm lost, what are you trying to say.
Sorry, its been a long day.
By PatrickM in forum Refrigerators & Freezers
Last Post: November 29th, 2011, 02:13 PM
By dcharletta in forum Refrigerators & Freezers
Last Post: December 7th, 2009, 08:05 AM
By Gibson in forum Sears Kenmore
Last Post: November 16th, 2008, 09:46 AM
By richard tomasetti in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: June 12th, 2007, 01:18 PM
By MarkF2 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: August 31st, 2006, 11:43 AM
